Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Equipment Usage, Soldering, Techniques, and Reviews
Thread Tools Display Modes
Old 04-16-2018, 07:08 AM   #1
spleenharvester
spleenharvester's Avatar
City & State: UK
My Country: UK
I'm a: Hobbyist Tech
Default Lifted pads
Very frequently (at least 1/2 the time) when I do motherboard SMD soldering (eg ceramic caps, SOP-8 packages) I seem to pull the pads off when I lift the part, even though the solder appears to be nice and fluid.
I use a cheapo 20W soldering iron, flux paste, leaded solder, desolder braid. When I try and desolder a SOP-8 for example, I usually lift the legs on one side by running a cocktail stick into the 'groove' behind them, but there always seems to be a pad come off with them.
Does anyone have any idea what I'm doing wrong? Is my soldering iron temp too low? Should I buy a temp-controlled iron, or maybe some sort of hot air gun?
__________________
Dell E5500 | P8700 2.53GHz 3MB | GS45 GMA4500MHD | 4GB DDR2 | 64GB Crucial M4
spleenharvester is offline   Reply With Quote
Old 04-16-2018, 08:09 AM   #2
vinceroger69
City & State: Nuneaton Warwickshire
My Country: uk
Default Re: Lifted pads
I only do electronics as a hobby but have one of these hot air stations and use it a lot on smd parts/mobile phone/tablet screens and recently changing tv leds it works fine for what i want it for i offered them 25.00 and they accepted ive had mine about two years now and no issues so far with it.
https://www.ebay.co.uk/itm/2-in-1-So...EAAOSw43haHCvX
vinceroger69 is online now   Reply With Quote
Old 04-16-2018, 10:04 AM   #3
diif
City & State: Midlands
My Country: England
I'm a: Professional Tech
Hot air every time, unless it's a tiny thing I can remove with a blob of solder on my iron.
diif is offline   Reply With Quote
Old 04-16-2018, 10:09 AM   #4
vinceroger69
My Country: uk
Quote:
Diif any idea how you check the calibration on these cheap units? the temperature is easy but air flow do you calibrate it on max or what my usually working air speed would be.
Old 04-16-2018, 10:23 AM   #5
diif
My Country: England
It depends on the job as to the temperature and speed. I work by feel so I don't need to calibrate it. I have it so SMD stuff is not blown around and rarely change it. It's usually the temperature I play around with a little.
Old 04-16-2018, 10:28 AM   #6
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
My Country: USA
Line Voltage: 120VAC 60Hz
My cheapo hot air unit came with this weird two prong wire thing. It actually is a "pusher" that you use to gently push things off their pads when using hot air. The prongs are made of spring steel and are thin so you can only give so much force to push it off the pads. Of course don't spring it up, lest the component goes flying when the solder melts - it is a spring after all!
I don't know what you can do with a solder iron, sounds like a recipe for destruction if you're using it for surface mount.
eccerr0r is online now   Reply With Quote
Old 04-16-2018, 10:37 AM   #7
vinceroger69
My Country: uk
This is what ive been doing too be honest, i just heard calibration mentioned in youtube video regarding these stations but i think this was regarding hacked firmware and mines just standard.
Old 04-16-2018, 12:16 PM   #8
spleenharvester
City & State: UK
My Country: UK
Thanks very much all, I didn't realise hot air was the go-to tool - I thought soldering was first line for basic SMD stuff. I'll buy one of those hot air stations now.
Old 04-16-2018, 12:47 PM   #9
stj
stj's Avatar
City & State: Europe
My Country: some shithole run by Israeli agents
yep, search 858d on ebay.
dont go over 360' and dont leave it on it's side - it can melt it's own case if you abuse it.
stj is offline   Reply With Quote
Old 04-16-2018, 02:41 PM   #10
vinceroger69
My Country: uk
i forgot too add the link for the extra nozzles i brought
https://www.ebay.co.uk/itm/10pcs-Hea...4383.l4275.c10
Old 04-19-2018, 04:38 PM   #11
llonen
City & State: united kingdom
My Country: hampshire
Line Voltage: 240 VAC 50Hz / 110 VAC 50 Hz and 415 VAC 50Hz
I would not recommend for professional rework purposes and have not used it in a long long time, but Quick Chip might get you out trouble with some SMD rework its a low melting solder alloy which allows the joints to remain fluid for longer. I would say though as above invest in a decent hot air station.
llonen is offline   Reply With Quote
Old 04-19-2018, 05:55 PM   #12
petehall347
City & State: worcester
My Country: United Kingdom
I'm a: Knowledge Seeker
quick chip can be bought from elsewhere for lower cost . it is also use for pipe bending in working steam engine models . cant remember its proper name right now .
petehall347 is offline   Reply With Quote
Old 04-20-2018, 05:39 AM   #13
llonen
Yeah I certainly would not pay what they are asking for quick chip, which is only a Tin Bismuth Sn42Bi58 alloy with a melting point of around 138 C, there are a number of companies that supply the stuff on rolls.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2019
Powered by vBulletin ®
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
