Hello all,
i have an lg 55ls4500 that appears to have a brightness problem, when i turn the brightness up past 75, i have a decent picture, but when set on 50, which is supposed to be standard setting, i start getting a negative picture which gradually gets worse as the brightness decreases.
When i first got it, the image from other input would stay on screen forever, so i changed the main board, which seemed to help, but still had the negative image in the picture here and there , had to reall play with adjustments to get a decent picture. So now i changed the t-con board also, which made little differance.
so, of course i checked all named power supply voltages, 12,24,5 all there and the led power is 69volts. im not exactly sure what it supposed to be. the 400v is around 393v
So, where i am at is i can get a good picture with brightness around 85-90
any ideas what i am missing? i have attached 2 pics, one with bright down and other with bright up high.
