Hi Experts,
I have a here, a 40" LED TV brand is skyworth, I thought it was a backlight issue since I can see a display using a torch. Voltage are good up to 37V output to LED. I opened it up and test all the backlight to find out nothing is busted. All are good. I rehot the TPS61196 Led dirver IC, assembled and test, seeing dispaly and I even the set the backlight but after closing the unit and boot up again, same issue occur, ni display again likeno backlight. Do you think the Led driver IC is the culprit? Voltage are good to the backlight. Any idea is very much appreciated.
Pics attached of the board.
