inspiron 3521 ISL95833 +VCC_CORE ok, But no +VCC_GFXCORE_AXG.
    Hello brothers, now i have problem with dell inspiron 3521. first time it has no display. i check vcc core and graphics core missing. i have changed isl95833hrtz, now VCC_CORE is ok but no +VCC_GFXCORE_AXG found. Please help me why graphics core missing.there is no short in PL700 and PL701. is isl95833 is bad?????? or which voltage is recquired for enable graphics core.
    P/N: LA-9104P
    Last edited by SMDFlea; 02-26-2021, 06:13 AM. Reason: added inspiron 3521 to thread title
    Re: ISL95833 +VCC_CORE ok, But no +VCC_GFXCORE_AXG.
    what voltage on pq700, pq702 and pq703 ?
      only pq700 pin 5,6,7,8 have 18v and oter pin have no voltage
        check voltage on pl800 when power on, and without power supply and battery if it's shorted.
        i think that vccgfxcore is the voltage that tell the isl95833 that vga is ok and that can turn on vcc core... infact on page 53 is vga power while on page 52 it's vcc core
          Thanks dellxps15 to reply me. but this motherboard have no pl800.
            it should be near pu800 check pq802 pin 5-6-7-8
              Check with an magnifier the legs of changed ic are soldered correctly ?
                i have another same board inspiron 5521 which have amd graphics thats why its need pl800. But this motherboard only have intel graphics and no amd gpu so its pl800 place is blank. i removed and resolder this chip. but same. thanks for reply me......
                  [QUOTE=nazrul145;466481]Hello brothers, now i have problem with dell inspiron 3521. first time it has no display. i check vcc core and graphics core missing. i have changed isl95833hrtz, now VCC_CORE is ok but no +VCC_GFXCORE_AXG found. Please help me why graphics core missing.there is no short in PL700 and PL701. is isl95833 is bad?????? or which voltage is recquired for enable graphics core.
                  P/N: LA-9104P[/Q
                  HTML Code:
                  Dear i have dell inspiron 3521, i facing same problem no vcc core & vcc gfxcore voltage. as per schematic diagram there is
                  1) VR_ON enable signal is available ie 3.3v
                  2) VDD voltage available ie 5v
                  as per concept ISL95833 should generates VCC CORE & VCC GFXCORE but this two are MISSING.
                  Mr. Nazrul please suggest me what to do.
                  whether i need to change ISL95833, but still i have not replaced it. because above voltages are present.
                    Replce chip with working one.
                      I am working on this same board. You should also check the high side fet PQ700, mine was shorted. Same symptoms. I havent replace the ISL95833HRTZ yet.
                        hi guys i have a problem with dell 3521 m-board 2 beeps i will try all thing change ram but still there plz help
                          hi guys
                          I have a la-9104, Its all ok but VR_On power is not appearing, somebody shoutout this problem, plz help!!!!!!!!!!!
                            VR_ON doesn't appear on pin no 2 of the ISL95833 then the +VCC Core and GFX Core also zero, is somebody has fixed? .......
                              Check there is a short on B+ or not .
                                Dear Kirro, There is no any B+ short.......
                                  desperate with same exact issue here.. VR_ON missing
                                    its look like missing signal. +VCC_GFXCORE_AXG is on if all signal is good. search the power sequence path.
                                      is there any missing pqwer rail?!
                                        i have the same problem on dell 3521,no vcc core pl700 & pl701 shorted to ground what can i do?
                                        "The Quieter You Become The More You Can Hear"
