What resistor(s) do I have to change to reduce the standby voltage from 5V to 3.5V? See attach photo. I have several brand new LGP32-09P that could be dead stock so am trying to use them to replace LGP32-11P. The amps and voltage rating are written on both supply and are the same except for the standby voltage. I also know that the arrangements of the voltages at the connectors are different but I can fix that problem. I just need to get the 5V down to 3.5V on the LGP32-09P in a professional way . Thanks for helping in advance.
Replacing LG PSU LGP32-11P with LGP32-09P?
Re: Replacing LG PSU LGP32-11P with LGP32-09P?
BTW, when you bring down the Voltage from 5V to 3.5V, you need to adjust the value of R205, 206, 207 according otherwise the Opto current transfer will not be correct.Never stop learning
