LA-A996p rev:4.0 dump
    I need bios dump for LA-A996p rev:4.0.
    I have the old bios (8MB).
    Does anyone have it?
    Re: LA-A996p rev:4.0 dump
    try this and reply.
      Thank you but I have same problem.
      Probably kbc problem....
        whats the problem?
          does boards have a common problem with SUSP command , and major part of does that enter the lab here , have issues wiith KBC , after rewriting KBC usually all is fine after.
          somethimes require its replacement.
          but firstt oof all wich are the issues you are feeling?
            I have problem with kbc, I changed it and second problem with cpu.
            I give it back ...
            Thanks for help...
                Originally posted by samuelnagy View Post
                Tell me if works fine???
                  So thank, i have 1 question, i have thé same h15 protected with administrator passeword,i have try to flash bios after no display,this bios firmware Can resolve this?
                    la-a996p io please
                      Originally posted by imranromi View Post
                      try this and reply.
                      Good it's working
                        test ok
                            Thanks guys
                              thank you
                                100% Test ok Org bios ...
                                  Pls help no display bios..
                                  Here back-up thanks
                                    Originally posted by burakdag View Post
                                    test ok
                                    thanks tested for me working 100%
                                    HP MODEL-15-G059WM ZS051-LA-A996P REV 4.0
                                      Thank you so much !
