Clean bga with ultrasonic
    Hi all, I read that in some cases to clear bga with a non ultra expensive (permit to change the frequency ) ultrasonic wash can damage the chip.
    Some experience....
    thanks
    Re: Clean bga with ultrasonic
    i clean hundreds mobile phone boards with ultrasonic bath with no damage.
    every good technician doing this after liquid damage.
      I use the same method with no problem, but I assume that the article I read, referred about an issue of separation between the die and the golden thread. It's possible?
      How liquid you use ? I try some liquid and various temperature but I have the best result , especially to remove the flux after a reballing, with a isopropil alcool at 60-70 C° or for particular cases an ersa solvent. with distilled water, the results are poor as well as with specific liquids, probably for the frequency, my bath operates at 44 Khz but I read of devices operating at much higher frequencies.
        i dont using utrasonic bath after reball. only for removing oxidation after liquid damage under the bga.
          The only damage i have read about is if the chip touches the inside of the bath, which can cause physical damage to the chip and also the bath. The chip/item should be in a try or suspended.
          I use IPA in my bath but i don't clean BGA chips in mine.
            Agreed to diif. They are not ESD safe.
              ofcourse thats why all using some kind of nonmetal "carpet" on bottom of ultrasonicbath
                I find the article, can I post the full link ?
                http://www.xxxxxxx.org/mart/50226F.shtml
                  all I get is this,
                  (Controller file /home/orgclini/public_html/xxxxxxx.org/libs/controller/mart.php not found.)
                  Is it just me again
                    maybe he meant this link
                    http://www.ipcoutlook.org/mart/50226F.shtml
                      I am a newbie to this forum and not know the policy to post a link.
                      the right link is http://www.ipcoutlook.org/mart/50226F.shtml
                        thanks
                        Cheers jasko
                          An ulrasonic bath shouldn't damage the bga. I've done not only phones, but also CPUs, tablets, laptop motherboards and other PCBs. The weirdest thing that I have fixed with an ultrasonic bath was an iPad camera. Isopropyl alcohol didn't work, but after the bath it worked like new.
                          Keyboard not detected, press F1 to continue...
                            Can somebodt tell me what liquid mix to use in ultrasonic for mobile and BGA
                              I did not know an ultrasonic cleaner is not ESD safe - i removed the plastic tray from mine when i got it, and forgot where i've put it. I've cleaned lots of BGAs in it and it didn't damage any of them. But i always put the BGAs in with the pads facing up.
                              A working TV? How boring!
