is there any way to modify a USB to write protect it.
Modify USB Drive
Re: Modify USB Drive
Originally posted by keyboardcowboyThe drive that i want to modify is a Corsair Flash Voyager 1 GB,it uses a Prolific 2518 controller,i have seen its data sheet it does have write protect pins.How can i use it??
Try soldering on such a small chip is a risk: you may damage your drive, the usb port you connect it and lose all data on it. According to datashet, the controller supports the creation of "hidden" partitions with a Prolific utility (Prolific MFG kit): try looking for it. It's likely to be a Windows tools: hidden or secured partitions are unreacheable on all other operating systems.
OTOH if you don't mind risking damaging your usb drive, then backup all data and open it: I don't know how the WP pin should be connected nor I tried soldering on my drives, but if I were you I'd short SM_WMPIN to a ground pin or, even better, use a small switch to open and close the short circuit. If it does work, congratulations; if it doesn't and it smells burn ... controller gone at 99%. It's a risk.
ZandraxLast edited by zandrax; 06-29-2008, 03:33 PM.Have an happy life.
