hello
i have a Samsung LE40M87BDX/XEH and recently appears some problems with the picture,the problem is that the faces an especially noses, forehead ,cheeks its very white and shiny or turned to pink, i forced to adjust brightness and color very low and it was little better ,but became very dark. anyway that was the small problem because yesterday i try to "play" with the adjustments in service menu for a try to fix it,but i don't remember what i change,of course i thought if you push the factory reset even if you do wrong will be ok,but i thought WRONG, now i have totally distorted picture like moving oil and after 5 resets nothing happened,did someone have the full settings of service menu?or some other solution? thanks be forehead and sorry about my bad English greetings from bankrupted Greece )
