I'm not an electrical guy so bear with me. Today was my first use of a voltmeter ever.
See pictures of my PCB. My resistor and fuse readings were as follows.
F1: side "a" and "b" were both 0
F2: side "a" and "b" were both 5.0x volts
Resistors: Base / Pin 1(top) / Pin 2(middle) / Pin 3 (bottom)
U2 3.3 / 5.0x / 3.3 / 2.0
U4 3.3 / 5.0x / 3.3 / 2.0
U7 1.28 / 3.3 / 1.28 / .03
U9 1.5 / 3.3 / 1.5 / 0.0
U33 3.3 / 5.0x / 3.3 / 2.0
I also tested the component U3 which says 7805 on it at U3. This showed 0 volts on all 3 pins.
Please let me know if you have any suggestions. I found a youtube video but out of the gate their F2 fuse worked and mine didn't. Similar TV symptoms but different PCB readings.
