Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Computer Displays
Thread Tools Display Modes
Old 09-01-2018, 10:54 AM   #21
rrflorida
City & State: Tampa, Florida
My Country: USA
I'm a: Knowledge Seeker
Default Re: HANNS G HZ281 White Screen
Oh, that's a nice spreadsheet - thanks for the pointer. It indicates the tcon board is bad, but to check the panel first before replacing the tcon board. I'll search around the forum for how to do that.
rrflorida is offline   Reply With Quote
Old 09-02-2018, 11:56 AM   #22
rrflorida
My Country: USA
Well, I'm not sure how to test the panel itself - I jiggled all the ribbon cables to the driver boards with no effect. Looks like there is no availability for this tcon board, so I'll need to attempt to diagnose and repair the one I have. The u102 transistor (circled in red) measures 7.3k Ohms middle to right leg, and 100 Ohms middle to left leg.
Old 09-04-2018, 02:54 PM   #23
momaka
momaka's Avatar
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
I'm a: Hobbyist Tech
Quote:
Good find.
But left leg is the input, so 100 Ohms is not necessarily a problem.
That said, see what voltage is coming to the left leg of U102 (with respect to ground) and what voltage it is outputting on its right leg (again, with respect to ground).
Also, could you please tell us what part number is written on U102?
Old 09-04-2018, 04:11 PM   #24
budm
budm's Avatar
City & State: S.F. Bay area
My Country: USA
Line Voltage: 120V 60Hz
That is Voltage regulator IC, not transistor. See what Voltage you have on Vin and Vout pin.
I suspect the GAMMA Voltages are generated by U300, 301, get the P/N on both of them.
BTW, designator for Transistor is 'Q??', IC is U??
__________________
budm is offline   Reply With Quote
Old 09-09-2018, 07:55 PM   #25
rrflorida
My Country: USA
momaka and budm - thanks for the responses, really appreciate the help! I will gather the requested info Monday. Sorry for the delayed reply, was out of town.
randy
Old 09-11-2018, 08:05 AM   #26
rrflorida
My Country: USA
U102 is a 960T45. Left leg is 4.96V, right leg is 3.24V
U300 and U301 are both BUF 07704, which Mouser says is a LCD Gamma Buffer.
Old 09-11-2018, 10:39 AM   #27
budm
budm's Avatar
My Country: USA
960T45 is 3.3V regulator, it is OK. http://www.gmt.com.tw/product/datasheet/EDS-960.pdf
GAMMA chips may be bad, need to look up spec sheet.
Old 09-11-2018, 04:31 PM   #28
rrflorida
My Country: USA
Data sheet for BUF 07704 attached
Old 09-11-2018, 06:08 PM   #29
budm
budm's Avatar
My Country: USA
So now you have the spec sheet of the IC showing what each pin is for, start checking the Voltages and report the reading for each pin, that will be a starting point.
Old 09-12-2018, 02:04 PM   #30
rrflorida
My Country: USA
Below and attached (the formatting is messed up here in the post) are the voltage readings from the BUF07704 chips. The OUT side seems to correlate pretty well with the IN side.
Pin U301 U302 Name
1 13.13 0 VDD
2 12.46 6.55 OUT1
3 10 5.31 OUT2
4 9.29 4.34 OUT3
5 8.9 3.78 OUT4
6 8.11 3.07 OUT5
7 6.76 0.64 OUT6
8 0.12 0 NC
9 5.47 7.21 OUTCOM
10 0 0 GND
11 0 0 GND
12 5.45 0.63 INCOM
13 0.76 0.65 NC
14 6.75 0.64 IN6
15 8.11 3.07 IN5
16 8.89 3.78 IN4
17 9.29 4.34 IN3
18 9.99 5.31 IN2
19 12.45 6.56 IN1
20 13.13 13.14 VDD
Old 09-13-2018, 11:26 AM   #31
budm
budm's Avatar
My Country: USA
https://www.badcaps.net/forum/attach...3&d=1536778904
Look at INCOM and OUTCOM of U302: U301 INCOM is 5.45V, OUTCOM is 5.47CV, but U302 INCOM is 0.63V and the OUTCOM is 7.21V
Look at pin 1 of U301 and 302: 0V on U302?
Old 09-13-2018, 01:05 PM   #32
rrflorida
My Country: USA
Oh, I messed up pin 1 on U302 (VDD) - it's actually 13.13V, so ok there.
I see what you are saying on INCOM/OUTCOM on U302. I just double checked:
12 INCOM: .64 steady
9 OUTCOM: climbs from 1-3 volts up to 6-7 volts everytime I probe it (climbs for about 30 seconds)
Are you suspecting U302?
[NOTE: I somehow started using the wrong U numbers, but will stick with the current U301/U302 for consistency]
Old 09-13-2018, 01:51 PM   #33
budm
budm's Avatar
My Country: USA
Yes, I expect U302 to behave the same as U301, it is buffer after all.
Old 09-14-2018, 08:12 AM   #34
rrflorida
My Country: USA
Ok, I will attempt to replace the chip and report back. Thanks.
Old 10-04-2018, 02:25 PM   #35
rrflorida
My Country: USA
fyi - having trouble finding the part - Mouser just cancelled the order and said it is discontinued. More later..
Old 10-05-2018, 06:07 PM   #36
momaka
momaka's Avatar
My Country: U.S.A.
Maybe check with eBay. Sure there's a chance the part you get may not be genuine or high quality, but it could work fine. I've bought PWM controllers for motherboards before, and they worked okay. It's really only the high-power devices (MOSFETs, BJTs, and those STK stereo modules) that you want to either stay away from or use with lots of caution.
That, and the slow wait for the part to arrive from the far factories and shops of East Asia.
Old 10-08-2018, 04:36 AM   #37
Capt. Cap
City & State: SF, CA
My Country: US of A
Doesn't look like any reliable retailers have it available in small order quantities https://octopart.com/search?q=buf07704&start=0
but you can get a single BUF07704 chip here
Probably not the real thing, but like momaka says, it may work well enough.
Let us know how it goes, I could be in the market for one myself soon
Capt. Cap is offline   Reply With Quote
Old 10-08-2018, 09:11 AM   #38
rrflorida
My Country: USA
I ended up using eBay seller dicikey-max. We'll know more in 12-50 days.... Thanks for the suggestions
https://www.ebay.ie/itm/332274532555...m=332274532555
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2020
Powered by vBulletin ®
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
