Hi all, I'm new on the fourm and am working to bring a HP L1955 LCD monitor back to life. Its probably identical on the outside as the HOODLAM describes but the power inverter board is a little different. The board is a benq 48.L1A02.A00.
Inital symptoms are power light comes on flashes yellow then turns green and stays solid green but no display either with out without video input. With alot of squinting I can make out the menu display when the menu button is pressed so it looks like the video logic must still work. I tried a flashlight but still couldn't make out any more than the menu.
Opened it up and see initally two 1000uf 25V caps with black smudges on the top but not bulged. The main fuse is good but secondary fuse PF703 is blown and there are two darkened areas near two of the inverter transformers where it got hot. I replaced the two caps and fuse and gave it a try and the fuse blows instantly. WIth some tracing about one half of the inverter section has .2 ohms to ground and the other is several K. I pulled out the two 5707's for that section and one seems shorted and the other not. But a short still exists on the board with the 5707's out. I understand from other threads there is a mosfet (FU9024N) that drives these but I need some help figuring out which one it is. The SMD side of my board is different than the picts hoodlam posted. I'll post a picture tomorrow when I get them downloaded. I took my board into work and looked at it under the microscope to try to read the numbers on the chips and didn't find any that looked like 9024. I found one each labled W064d (Q811) and W0452 (Q810) in the area I expected the mosfets to be. The 4d and 52 are turned 90 deg to the rest of the letters. Am I reading it upside down? Q812 is a 8 pin package nearby with all four pins on one side tied together and 3 on the other side (effectivly a 3 pin device) labled 4431 and L48C. This chip is connected across the shorted traces and could also be bad. Any idea what it is? There also is a diode that I thought might be the culpret so I detached one end and it tests just like the one in the other half of the circut. I concluded it was probably ok and reconnected it.
Also while looking through the microscope I found what appeared to be cracks around the inverter transformer pins like what others described so I reflowed the solder there.
I'd like to save this monitor from the grinder so any thoughts would be appreciated.
