Need help with my Lenovo Y520-15IKBN BIOS!
    Hi everyone!
    My laptop powers on, fans spinning, HDD turns on, charging LED and power on LED lighting up as normal, but nothing on screen, then 5 seconds later my laptop shuts down abruptly, I'm suspecting a corrupt BIOS, even the keyboard backlight used to light up but not anymore.
    I have backed up the BIOS from my chip using CH341A programmer and followed a couple guides to flash the BIOS but still the same issue, I could be doing something wrong or some other motherboard issue, anyways can someone provide me with a fixed BIOS?
    I'll provide all necessary information, just tell me what is needed.
    I backed up the BIOS using CH341A programmer v1.34.
    Would love if all the hidden options in the BIOS are enabled.
    This is the link to the BIOS update from Lenovo website:
    https://download.lenovo.com/consumer...s/4kcn45ww.exe
    Thanks in advance.
    Re: Need help with my Lenovo Y520-15IKBN BIOS!
    Originally posted by Qattos View Post
    Hi everyone!
    Thanks in advance.
    try...
      Originally posted by peste View Post
      try...
      This didn't work unfortunately, same exact issue.
      Is there a way to disable discrete GPU in that BIOS file and boot using the integrated graphics card? just wanna check if my dGPU is the issue.
      Thanks for your time.
        PCH is dead!
          Lenovo y520-15ikbn Bios nvidia graphics
          I am looking for a bios for lenovo y520-15ikbn with nvidia graphics.
          DY520 NM-B391 REV1.O
          In the attachment I am sending the original, ripped batch
            Re: Lenovo y520-15ikbn Bios nvidia graphics
            Try...
              Originally posted by fire1234 View Post
              Try...
              After uploading the bios from Fire1234 there is a black screen and the laptop turns off after 4 seconds. On my original bios, the laptop starts up and when the windows starts to load (the ball starts spinning) the laptop turns off. Checked disk, replaced with another
                Post the serial number on the case
                  S/N PF12WQTP mtm: 80YY0074US
                    the bios posted by fire1234 is ok,the problem is somewhere else.
                    Edit: the serial number you gave is for a Y520-15IKBM ,the motherboard has an i7-7700HQ and GTX 1060. Are you sure the motherboard is a DY520 NM-B391 REV1.0 or is it an DY512 NM-B191 REV 1.0 .Is there a lenovo part number sticker in the memory slot area
                      Thank you for the information
                        Yes, the board is DY520 NM-B391 REV1.0
                        There's a sticker next to the ram
                        MB LENOVO
                        PN: 5B20P24389
                          DY512 NM-B191 REV:1.0
                          The device turns off senselessly, sometimes before the image appears,and sometimes it turns off within 1-2 minutes.
                          Could you please clean and edit the ec and bios files?
                            It's better to write your device serial number and full model type.
                            all donations are welcome,
                              Is there a file I can try?
                                Try this.
                                  Mine PF0XC175, MTM:80WK0128MJ, Y520-15IKBN. Anyone have the BIOS for it?
                                    always when you make a bios request, post the original bios of the laptop...
                                      Here's your New bios file, it's a virgin bios from Lenovo.
                                      As @peste said, you should take a Backup from your chip before use this new file.
                                        video card shows exclamation (code43)
                                        can you clean the file. thanks.
                                        Lenovo Y520-15IKBN (80WK)
                                        DY512 NM-B191 REV 1
                                        S/N : PF0XEV5J
