Clear ME Lenovo carbon x1 2-gen i7
    Hi i need help to clean ME thanks
    Re: Clear ME Lenovo carbon x1 2-gen i7
    Did you try to do it yourself first?
    ------> ME Firmware Cleaning Guide
    Become a Badcaps supporter
    Thanks to all supporters.​
      yes im trying and black screen
        And did it work before your cleaning attempt with this file?
          This file i have from another working laptop, laptop working on bios 3-gen but not recognized ssd
            So where is your original dump? What's the issue with your laptop?
            So your laptop is 2nd generation but you are trying a third generation bios. Why?
              original bios not working is only black screen
              I;m trying diferent 2nd gen bios and none of it worked, when i trying 3rd gen bios it start working
                Hmm interesting...
                Upload your original bios here, even if it's corrupted/non working.
                Post all information about your laptop such a board number, revision, machine type and so on.
                By the way, here is your cleaned file since you want to try exactly with it:
                  Thanks for help but nothing change, it could be hardware issue
                    Try this one .
                    removed,not working...
                      Originally posted by SMDFlea View Post
                      Try this one .
                      not working , starts and turns off
                        new one. Is that your original bios backup at post #1 or not.If it isn`t then post it. What is the motherboard part number .
                          i'm lost original, only file that works for me is from 3th gen but not see SSD and i can;t upgrade bios from 2nd gen.
                            What is the motherboard part number ,i have asked already . Vesko asked you too at post #8
                              I do a photo of motherboard
                                Try the bios at post #12 ,don`t use a 3rd gen bios. Remove all power,including the CMOS battery before flashing. After flashing, start it and leave it for a few minutes,even if it switches off.
                                  i trying but bios from post 12 not working, maybe bios from 3rd gen flashed MEC and now every bios from 2nd gen not working...
                                    Try this new one. If it doesn`t boot try it with no wifi card. Has the cpu ever been replaced
                                      the same, i installed 3th gen bios and works, but now how upgrade bios to good version xD Like you see :
                                      UEFI BIOS Version is from 3th gen
                                      and
                                      Embedded Controller Version is from 2nd gen
                                        Lenovo do sometimes reuse the same bios code across models and just change a few things. The gen2 bios has bootguard 4 ,ME 9.5 5MB corporate FW. The one you posted at #13 has ME 10 1.5MB consumer FW ,and bootguard is 0 .If the CPU has been changed for one with bootguard-0 from a different board that might explain it,not sure .
