pls Bios HP Probook 450 G5
    Re: hp probook 450 g5 5 blinks on caps
    working thanks alot
      Re: pls Bios HP Probook 450 G5
      Hp probook 450 g5 daox8cmb6e0 rev e bios is corrupted can fix it
        Hi everyone, Hp 450 g5 (DA0X8CMB6E0) UMA version with i7 CPU, not display and capslock bliking 5 times, fan at full speed. I tried clean ME, did not help, can anyone help me to rebuild attached dump? Thank you
          try..
            try..
              hi gays pls help me with this error
              How to fix WHEA_UNCORRECTABLE_ERROR
              HP 450 G5
              i change bios but no luck
              thanks
                Have a problem with 450 G5 caplock and ver num flash 5 times and nothing on sreen, any help please ?
                  Originally posted by genova View Post
                  hello,
                  have a problem with 450 g5 caplock and ver num flash 5 times and nothing on sreen, any help please ?
                  try dump from post#100 posted by mr.peste
                    hello,
                    try..
                      Originally posted by peste View Post
                      try..
                      Thanks it is all good, but where can i find some info like Feature byte, System board CT number, etc... ?
                        Given on the sticker
                        Or check on YouTube there is tons of video available
                          https://www.youtube.com/watch?v=9T57ktw8n3Y
                            thanks
                              Thanks but can not find CT number no more sticker on pc...
                                Check inside the battery compartment, and enter your serial here to get some more info such as Feature Byte - https://partsurfer.hp.com/Search.aspx
                                  Thanks SMDFlea, peste,qayyum786 CT number was the only missing one and this number was on the battery !
                                    You can find all the info in the bios using a hex editor,including the windows key. Text searches have to be in Unicode for the serial etc, apart from the win key which is in normal encoding,you can find that by scrolling down from the area where the serial is.
                                      Thanks for these infos
                                        Originally posted by jm801
                                        necesita ayuda con la reparaciĆ³n de bios, tiene 5 flash y luego el ventilador va alto y permanecer negro.
                                        try
                                          no funciona misma falla
                                          try this too
