X555ld rev 3.3
    X555ld rev 3.3
    X555ld rev 3.3
    nvdia 940m - n16s-gt-s-a2
    bİos ? Help me !
    Re: X555ld rev 3.3
    i need this bios
      Re: X555ld rev 3.3
      Originally posted by holz.dl View Post
      i need this bios
      https://www.badcaps.net/forum/showth...id=8&styleid=7
        Re: X555ld rev 3.3
        please help ineed bios
          Re: X555ld rev 3.3
          https://www.badcaps.net/forum/showth...ghlight=X555ld
            Re: X555ld rev 3.3
            thank u i will try but not workink.my motherboard x555ld rev 3.3 n16s-gt-s-a2 nvidia cards not working
              Re: X555ld rev 3.3
              https://www.badcaps.net/forum/showth...ghlight=x555ld
                Re: X555ld rev 3.3
                hi again i try before this bios but winflash message bios file is not valid.
                this vram chip is n15 but i need n16s please help me
                  Re: X555ld rev 3.3
                  Post your original bios backup and post a good readable picture of the white/green sticker with the barcode/QR code on it .Its best to program the bios with an spi programmer if you have one. Winflash does have a force option though .
                    Re: X555ld rev 3.3
                    Hello I added photos and bios.This is the bios file that asus accepts and installs with its own program.and i added the latest version 307
                      Re: X555ld rev 3.3
                      Post YOUR bios backup,the one on the bios chip.Use an SPI programmer to backup, need the whole 8MB ,not updates.
                        Re: X555ld rev 3.3
                        i dont have a spi programmer please different way?
                        i crate backup for bios backup toolkit v2
                          Re: X555ld rev 3.3
                          can i use this. i will buy
                            Re: Asus main board : X555ld rev 2.0 & rev 3.3 & rev 3.6 bios
                            hello friends
                            asus x555LD rev.3.3(Case code:k555lb)but inside bios x555lbd.307(i think wrong bios)
                            n16s-gt-s-a2 nvidia chip inside.intel gpu work fine but gt940m is code 43 ?
                            please help me
                              Re: X555ld rev 3.3
                              Sure,if other methods to flash don`t work.The CH341A black pcb version might need modifying. Check if its output is 5V on pin 28,if so then do the 3.3V mod - https://www.chucknemeth.com/usb-devi.../3v-ch341a-mod ,there are youtube videos too and lots of other info about the mod if you search
                                hello friends
                                please help me
                                (334) X555LB on the white sticker is the bios that the board shipped with. So you need a X555LB bios
                                  Re: X555ld rev 3.3
                                  Try the attached bios,flash with AFUwin from here - https://www.ami.com/download/aptio-v...pdate-utility/
                                    Re: X555ld rev 3.3
                                    Hi again i received programmer(yes black pcb). created backup add here.I tried to write from ami before but bios did not accept it because it shows 306 ldb
                                      Re: X555ld rev 3.3
                                      see posts 15 and 17 .The bios at post 17 has your DMI + win key added .
                                      Use neoprogrammer or asprogrammer software
                                      https://www.badcaps.net/forum/showpo...04&postcount=7 NeoProgrammer
                                      https://www.badcaps.net/forum/showpo...6&postcount=10 AsProgrammer
                                        Re: X555ld rev 3.3
                                        The backup is not good,its corrupted, theres a few reasons for it.
                                        The clip isn`t held on steady or its not making good contact.
                                        The 3.3V volt mod hasn`t been done
                                        The default software is shit
