GNR TS902W no power , help please
    Hi
    I need some help from this magnificent community please.
    I have an 19" WXGA TS902W LCD Monitor made by GNR has no power
    no front light, nothing
    I have checked the power outlet and cable, fuses all good.
    I have checked the caps on both boards including the no signs of bulging
    There are no burn marks nothing on the boards
    The power board is made By Delta electronics and model number is
    DAC-12M034.
    I have seen that this power supply is used in other monitors
    If some one has the schematic for this board, then please share.
    I know I can buy a used board and replace but would prefer to fix this Myself
    There is no voltage on the pins that connector connects to on the board
    There is mains voltage coming in
    Please can some one help me
    I will appreciate it very very much
    Many Thanks in advance
    Re: GNR TS902W no power , help please
    Bump
      Ok, it would help if you posted clear photos of the power supply board.
        The power board seems like it is used in other devices
        I googled the power board model number
        Please can some one help me diagnose this
          Attached Image of My board
          Taken from google
          Looks the same
          I don't see any burn marks or burnt components
          checked the fuses
          all ok
            Taken from google
            Looks the same
            checked the fuses
            all ok
            No we can't do much with a photo of another board taken from Google. We actually need the photos of YOUR board, both sides.
            Which fuses did you check, please mark them on the photos you will upload.
              Tested all the fuses marked f on the pcb
              Also checked the smd 0 fuses
              Will appreciate anyones help with uploaded image
              Please.
              Many thanks in advance
                So are you going to post the photos of your board? Can't help without them.
                  I posted a photo of the board
                    So what DC Voltage do you have between the two legs of the main filter cap (120uf 420V)? Be real careful not to touch anything in the hot side.
                    We also need the straight shot pictures of the top and bottom side of YOUR board.
                    What is your country AC line Voltage?
                    What is revision of your board?
                    The one you show is REV 02A.
                      Probably need to replace the small "start-up" cap on the power supply board.
                      After checking the voltage across the primary cap as budm suggested above, check the voltage on the output of the power supply. Looks like there are 3 output voltages: 3.3V, 5V, and 12V. Most likely, the 5V and 12V should always be ON, as long as the PSU is plugged in. Posting pictures of your board (top and bottom/solder side) would be helpful to give you more troubleshooting suggestions, especially if they are bigger and better-focused than the one you posted from Google.
                        thanks for the response
                        what would be the correct voltage on the startup cap
                        also there is no output voltage at all
                          Should be around 160V DC if you are in North America, double that if you are in Europe. It would help a lot if you posted high resolution photos of your boards, both sides.
                            There is no "universal" correct voltage for the start-up cap. It all depends on what PWM controller your board uses for the power supply section. You find the datasheet for it and see what is the minimum start-up voltage. If the start-up cap has less than that across it's terminals, there's something wrong with the circuit (or the cap itself).
                            In any case, just change the start-up cap first. It's the easiest route and ensures that this is no longer a potential problem (or the problem itself).
                            Yes, that can be a symptom of a bad startup cap. Other possibilities are blown output rectifier, bad output caps, blown component on the primary.
                            Since you don't have an output voltage, try measuring the voltage across the big 400/450V primary-side capacitor. As rddube noted, you should get either around 160V *DC* if you're in North America (or any country with 110/120V AC) or two times that in countries with 220/230/240V AC. BE VERY CAREFUL when you measure that cap - you're dealing with LINE-connected components here. You don't want to touch primary-side components with your hands when the power supply is plugged in.
                              Hi
                              finally got round to fixing this
                              The measured DC voltage on the primary cap is 324V
                                Sorry for asking again, but can you post clear large photos of both sides of your power board, we can then help you diagnose the problem.
                                If you measure 324V on the big cap (be careful when measuring on the hot side of the power supply), are you in Europe?
                                  Hi
                                  Yes in EU-UK
                                  240V AC
                                  Stuck on what next to do
                                  checked fuses and zero ohm resistors again
                                    Attached are photos of My LCD Monitor Power board
                                      As Momaka suggested, have you changed or checked the startup cap? Can't really tell from the photos but it looks a bit bulged?
                                      Also, when you say there are no output voltages voltages, what are you using for ground for checking? You can't use the same ground as on the hot side of the power supply (do you see the line separating both sides of the PSU) ? Use a ground on the cold side of the PSU and measure the voltages that are on the connector (they are printed on the circuit board)....do you get anything?
                                        Hi
                                        Thanks for the reply
                                        I checked the startup cap and got 324V
                                        I did not change
                                        It looks flat, i just checked
                                        I checked all the voltages on the connector using the ground pin but nothing
                                        i checked again using a screw hole, also nothing
