DA0X8MM6D0 REV. D schematic needed
    Hi everyone:
    I desperately need the schematic for the DA0X8MM6D0 REV. D MoBo.
    It is an HP 450 G7 laptop. In the MoBo you can also read MODEL: X8M-6L.
    Thanks in advance!.
    Re: DA0X8MM6D0 REV. D schematic needed
    Originally posted by fichamba View Post
    Hi everyone:
    Thanks in advance!.
    here is boardview
      Thanks alot . I need schematic for the same board please??
        pr9301 burned. I want the value .
            pr8630 und pr8611 burned. I want the value .
              0 ohm
                pu9600, pu9601 what kind of microcircuit is it?
                Thank you...
                  here is boardview
                  schematic please or at least help me identify this TYPEC IC controller it doesn't have part number coz its burnt shorted. its also doesn't have details in boardview.
                  after i removed the IC short is gone but it doesn't boot 3.3V,5V and 1.2v are present standby after i removed the IC shorted.
                  or maybe someone here know how to bypass this IC without replacing this coz i use the 19v adapter instead of type c.
                  just to work with normal adapter i wont use the typec.
                    i also found this datasheet it looks simmilar is this okay to replace?
                      for you
