I purchased an used Compaq EVO D510U (Ultra-Slim Desktop) and while it boots (I can't do any more testing because I don't have an USB keyboard and can't get past POST), I noticed 3 leaking capacitors and 1 bulged one. These desktop is very compact and may not have very good cooling?
Obviously, I want to replace these 4 Nichicon 2200uF 6.3v, 10mm diameter, 20mm height, series HM(M), 105C. See pics.
There are 7 Nichicon 2200uF 6.3v similar ones that look good with flat tops. It seems that the sentiment (but not consensus) from some on this forum is to replace them all regardless because if one fails, they *might/will* all fail, but since my soldering skills are a "D-" right now, I'm a little bit hesitant on a board this small with a lot of SMT chips next to the capacitors.
Opinions on "don't fix it if ain't broke"? From skimming this forum, Nichicon seems to be a good name?
I'm looking to replace them with either the
a) Rubycon MCZ 2200uF 6.3v 10mm diameter, 20mm height, 105C
Rubycon part number: 6.3MCZ2200M10X20
OR
b) Rubycon MCZ 2200uF 10v 10mm diameter, 25mm height, 105C
Rubycon Part number: 10MCZ2200M10X25
My reason for choice b) is that I could potentially use this capacitor for future fixes in other devices as it has a higher voltage rating. I have read that as long as the uF is the same, you can go a bit higher on the voltage.
Do you think I should stick with the 6.3v or go with the 10v? I may need just one 20mm height for a tight fit, but 25mm is will work for the other locations.
OR
