Harman/Kardon Onyx Bluetooth Speaker - No Power
    Re: Harman/Kardon Onyx Bluetooth Speaker - No Power
    https://www.badcaps.net/forum/attach...8&d=1490813608
    Check the RESISTANCE between the two legs of C713 (the smallest cap of the four caps) to see what it shows. Make sure to report if the reading is in Ohm, K Ohm, or M Ohm.
    BTW, that black carbon on the board should be removed, it is conductive.
      C713 = 0.6 Ohm, but i have only usual multimeter now.
      Black carbon will be removed certainly, i have not started the repair, only wiped with alcohol.
        Well, more likely one of those 4 caps is shorted out or the IC itself. I would carefully remove hose caps one at a time to see if the shorts will go away.
          Harman/Kardon Onyx schematic diagram
            Nice! Thanks
            -David VanHorn
              I'm bad english . I have onyx studio no power . I checked board see D300 explosive and U700 short circuit . I have replace new D300,U700 and still not work ? Anybody help me fix this ? thank
                Are you getting 4.7v from the new U700?
                -David VanHorn
                  I removed C306 and turned on ok but not charging battery . I connect apdator and remove battery and check Vbat pin is 0V
                    U701 is probably faulty, or C706 shorted?
                    -David VanHorn
                      I no find replace U701 IC . You can help me new solution ? . I plan to mod a extend power stepdown module for charging battery
                        Finally . I modding power charging battery by LM7805 and everything is OK . But charging battery near 8 hours when battery is very low,can't to start system :P . I'm no care because I alway using power apdater,sometime i go out to use on battery . Thank a lot
                          Hello everyone
                          I have the same Onyx Studio that does not turn on.
                          The BC57E687C Bluetooth chip gets warm after 1 minute with the AC adapter connected.
                          I hope youcan help me please.
                            Hi AGENT24!
                            I have an ONYX STUDIO 4. I plugged my scooter charger into it. The charger IC is burnt out. That's all it looks like visually. I would like to fix it. Unfortunately, I can't find a plan for it anywhere. Could you help me? I can't find a service manual link either.
                            Thanks in advance
                              Originally posted by csabikat View Post
                              Hi AGENT24!
                              Thanks in advance
                              Hello everyone!
                              Here is the Onyx studio 4 service manual
