Re: No power on a Acer AL1916
Finally, results! I tested using the second method and immediately after shorting the pins with a screw driver the led turned on, the screen didn't but at least it's a start. This happened with both monitors!
It might be a small part but I think I may be able to solder a new one in if you believe this to be the defect. I searched for MAX810M on digikey but there were more characters after the "m". I was going to order this part number MAX810MTRGOSCT-ND. Is That correct? Thank you so much
