Lenovo G560 LA-5752p NO Power No Light
    Re: Lenovo G560 LA-5752p NO Power No Light
    SUSP# comes after SLP_S3#, that comes after SLP_S4# and SLP_S5# itself. So check the SLP_S3#, SLP_S4# and SLP_S5# signals.
      i got this prblm in dell 3521.
      SUSP# was not generating frm io
      in that case my PCH_RTCRST# was 0v
      it should be 3v
      rtcvcc to pch_rtcrst# 20k resistor was open
      Simply check 32.786mzh at rtc crystal
      i dont know it will work on ur lenovo but u may check
        Yes Piernov is very right
          Thanks for replying@piernov. I know that but unfortunately SLP_S3#,SLP_S43 and SLP_S5#-All are missing.
            it should be 3v
            Checked RTCVCC and is not shorted. Though PCH_RTCRST# is shorted .
              Finally arrived at the conclusion that PCH is bad as PCH_RTCRST# shorted on the PCH side on CLR_P3 pad. Removed PCH and shorting is gone. I've replaced the PCH and got display.
              Thanks to all for your valuable time.
                1,5volt on my motherboard is broken so it turns 3 sec on and off. Please check your PQ48 for short circuit
                  I gotbthe same issu .susp# is 1.5v .
                    Guys Check PU7, In this board, most of the time the lower pins of the ISL gets corroded. PU7 Generates 1.1v through PL8
