Knew it was there but after a power failure my system started to really show signs of a bad cap as it would constantly reboot itself before it could even POST or just lock up on POST.
Board is an MSI 865PE.
I'm replacing all four of the 16v 1500 KZG's. While I was preparing to remove them however I noticed there was dirt that I could not clean off one of the ferrite cores, one of the caps and one of the FET heatsinks. Upon closer inspection it looked like at least one leg of one FET was discolored and oxidized. Pulled off the heatsink and there was a square soot outline.
Yet with these evident signs I could not find either FET to be shorted. Gate to Source are infinite with both pins reading between drain and either gate or source. I do believe neither is blown open either, right?
System never unexpectedly turned itself off before. Only time it gave magic smoke was when a poly fuse on a USB card committed suicide.
