Hi I had a circuit board that had a problem with the monitor not turning on. Sometimes it would turn on, other times it would stay black and would not be detected by the computer. The problem got worse and worse, eventually the monitor did not turn on at all when connected.
I recently purchased an ESR meter and was testing the caps on this board, and I came across two posable caps that may be bad, (though no physical damage shows).
Below is a chart I made with all the info I gathered. Note all caps are rated at 6.3 volts, 1000 uV.
Cap 11 has a 10% lower reading then what its rated at, so could that be the cause of the LCD problem? Cap 13 also has a low reading, allthough not quite as bad as cap 11 so would that one be considered bad as well?
Note- I am only doing this as a test to see what a bad cap reading looks like. Unfortionatley I can not test this board even if I replaced the cap because this board was labeled as "scrap" several months ago and has since picked up a bit of damage on the CPU pins where the cpu attaches. But I am just using this as a test as I said, because when I was working on this several months ago I thought the problem was due to a bad capacitor but was not sure. Now that I have an ESR meter I figured I would try to see if I can locate the bad cap(s).
One other question I had is why the caps had a higher ESR reading when they were removed from the board? Seems a bit odd.
