Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Audio Equipment
Thread Tools Display Modes
Old 02-13-2020, 08:52 AM   #1
garrymc123
City & State: Ayrshire
My Country: United Kingdom
Line Voltage: 240v 50/60hz United Kingdom
I'm a: Knowledge Seeker
Default Jvc TH-D258B No power on standby led
Hi, Guys, I have 16v from the power board going to the audio processing board but not sure what to check after this to diagnose the problem
Any help much appreciated
__________________
Your never to old to learn
garrymc123 is offline   Reply With Quote
Old 02-13-2020, 06:04 PM   #2
budm
budm's Avatar
City & State: S.F. Bay area
My Country: USA
Line Voltage: 120V 60Hz
Default Re: Jvc TH-D258B No power on standby led
So the how many Voltage outputs are there from the power supply board, just single 16V output?
Pictures of the power supply board?
__________________
budm is offline   Reply With Quote
Old 02-14-2020, 05:42 AM   #3
garrymc123
Thanks budm for your reply yes only on output from the power supply and I have attached pictures of the power supply
Old 02-14-2020, 03:55 PM   #4
budm
budm's Avatar
My Country: USA
Quote:
https://www.badcaps.net/forum/attach...0&d=1581605478
OK, that means the main board has the Voltage regulators, and buck converter to change the 16V to lower Voltage to run the processor.
I see at least one switching power section where the black inductor with '150' printed on top, I would check the Voltages between the two legs of those SMD Lytics caps to see if they show any Voltages.
You should also upload the pictures of the bottom side of the main board, there may be some linear regulator IC's on the bottom side too.
Old Yesterday, 04:58 AM   #5
garrymc123
Hi Budm thanks for your info I have 5v on both sides of the cap and I have uploaded a pic of the bottom of the main board
Thanks for your help
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2020
Powered by vBulletin ®
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
