I am surprised there has never been this problem identified as it seems it is quite common for AL2023 or AL2023W in here. The problem usually needs some time to occur but when it does, it behaves as you can see in attachement. It gets into loop when it is starting, after some time it powers up. After another time it starts showing "no signal" window over what clearly signal is and sometimes turns off for a while.
The problem is in signal board, that's for sure what I can tell, however where exactly, I don't know. This display has been almost completelly recapped but it does not seem to be capacitor problem, few years back I did 15 of these and it was not solved by 100% complete recapping. However, the problem seemed to be occuring only with some computers, elsewhere it was fine.
Any idea? Bad firmware? Some SMD components on the signal path? The microprocessor itself?
ADD// seems that AL2423W had the same problem. Guess what - they have the same signal board.
