I was given an LG 60PB5600 after the original owner said they didn't want to spend 145 for a replacement board.
The tv powers on and has static I can tune to Ch3 and play a movie on the VCR of which I can hear but not see.
When the TV turns on it lights up gray for about 3 seconds then goes black and the sound turns on.
Upon opening the TV I found the HDMI port was broken off then someone tried to glue it on successfully shorting many of the pins. Despite this, the original owner said they were able to use the composite input to watch tv still prior to it going black.
In an attempt to see if it was worth fixing I Jumped the pins near R651 and R652 to initiate a test sequence with no luck i additionally jumped RL_on to 5.2v on the P/S with the same result (nothing but black screen).
The green light on the CTRL board is flashing short, short, short, Long. If i jump the board and remove ribbon cable to main board it gives flash:Long short, long,short
Thanks for your help in advance
