AM2+ and AM3 socket ?
    Guys,
    Can I use AM2+ CPU on AM3 socket ?
    Do they have the same pin out ?
    Re: AM2+ and AM3 socket ?
    Originally posted by bianchi77 View Post
    Guys,
    No, they support different cpu's and memory.
      Amd Cpus are very tolerant regarding different sockets ..Many Amd Cpus for AM3 socket can be used on AM2+ . The last one i did was a Phenom 2 on Am2+ , but they will show less performance of what are they supposed to show , because they cannot benefit from their equipped special extensions and features .
      Best way usually to confirm this tolerance is to download the board manual and compare what Cpus can usually take..
        can I use AM2 CPU on AM3 ? I have Athlon 64 x2 3800 but the motherboard is AM3...
        I don't have AM3 processor for a test...
          If the motherboard supports DDR2 memory then yes. If the motherboard uses DDR3 then it won't work. AM2 and AM3 processors are pin compatible, but AM2/AM2+ processors only support DDR2 memory because the memory controller is on the cpu.
          For future reference
          AM2/AM2+ = DDR2 only
          AM3 = DDR2/DDR3
          AM3+ = DDR3 only
            The motherboard is :
            ASUS M4A89GTD
            may be you guys have more infos ? I tried reading from asus...but may be someone else has a different knowledge...
              info :
              https://www.asus.com/Motherboards/M4...pecifications/
              looks like I'm gonna need AM3 and DDR3 only...
