Bob Parker ESR Meters
    Re: EVB ESR Meter (Bob Parker Design)
    I will agree about the probes. The jacks seem to be pretty good, but the tension on the banana plug is low and the do not make a stable conection. I have to hold real still and wait 5-10 sec for the reading to stabilize.
      Hi all
      Yes gdement you are right re the silkscreen being a mod for MKII according to info
      Sorry to hear of your drama's
      I have Both MKI MKII
      The MKII I bought first few months ago see pics on page 2 its is marked as the MKII version PCB (10/03)
      I think I got a dud cause it didn't have holes for the 220 uF Cap either
      (I had to mount it on the back)
      I paid $70 odd AU for it..it was $10 off normal price if memory serves me.
      I bought the MKI for the fire Sale price it was the last one in the shop.
      I don't think there is any component or circuit changes
      (Haven't absolutely checked thought)
      Apart from I knew firmware and the use of 1V5 batteries as opposed to the 9V one used in the MKI
      MKII is the improved version of the MKI
      As to your problems with the bannana leads, well see if you can source better quality plugs or leads is one idea.
      If you go the other way, use a grommeted hole and a stain relief clip or you could possibly try on of those screw down cord clamps but you may not have enough room for one on them I think.
      The zero function should take care of any spurious capacitance etc with the leads
      if you want a pic of what I am talking about let me know.
      I use my multimeter leads or the leads that come with my capacitance meter
      Bit better quality then the cheapies supplied
      So yeah best advice buy some good quality leads or plugs
      (sockets and probes for that matter if you don't think they are up to it).
      I suppose the big question then becomes were do you get decent quality connectors these days?
      If you don't mind, Post some pics of the mod if you go with that
      Cheers
      Per keep us posted mate
      You step into the Road, and if you don't keep your feet, there is no knowing where you may be swept off to." Bilbo Baggins ...
        If you've got some completely-evaporating contact cleaner like CRC CO, spray it all over the plugs and jiggle them around in the jacks before it evaporates. That usually helps. Also give the probe tips a brushing with a wire brush occasionally.
        The problem is that on the bottom range, the meter's reading 1/100ths of an ohm, and varying contact resistance shows up real bad.
        It is a good shrubbery. I like the laurels particularly...
          Thanks for the info, Bob!
            welcome to crapcapland Bob!
            thanks for designing the meter it brings troubleshooting to another level.
              As I told kc8adu, I've been looking at what's going on here whenever I see a lot of visitors to my ESR meter web page coming from this forum. He talked me into joining up, so you can blame him for me making a pest of myself here!!
              Before I forget, I really appreciate the nice things people have been saying about the little ESR meter I designed way back in the middle of 1995. It's that old now! Thanks!
                Originally posted by starfury1
                Humm a quick look at the meter comparison at Anatek reveled this....
                Not sure if its in ref to MKI or MKII Kit maybe both
                They were not specific as to what this "degradation in the components" was?
                (apart from "Good, quality of components has degraded recently")
                Still at $80 AU it might be something to winge about at $25 AU guess not
                Anatek Comparison of ESR Meters HERE
                Suppose the short answer is replace any parts you consider are lower quality with a better spec device.
                If you think it really needs it.
                I didn't see this info till now or other wise I would have posted it along with the original post on the $25 deal
                All that's 'degraded' that I know about is that the 7 segment displays they've put in recent kits aren't very bright. For those lucky enough to be in the USA, Mouser Electronics sells Kingbright SC56-11EWA ones for about $1 each, which should be much better and they just plug into the socket.
                I'm not sure if they're available Down Under....
                  Re: Silicone Chip's ESR meter kit @ DSE (AUS)
                  Originally posted by tazwegion
                  Just picked mine up (thanks for the tip), shop assistant said the $79.95 -> $24.95 price drop reflected the low interest in this particular kit project, hence it was his belief that this was a product run out special
                  So folks... come get 'em while they're HOT!
                  "Low interest"....? The guy's a fool. It's simply because DSE's management has made the executive decision to stop production of all kits and they're trying to get them all out the door so they can use the space for more phone answering machines, MP3 players and vacuum cleaners.
                  There's still a lot of interest in ESR meters!!
                    dse going the way of radioshack here?
                    should be renamed cellphoneshack!
                      Radio Shack had a chain of stores here called Tandy Electronics. DSE bought that chain and combined it with their existing operation. Maybe that's where their present consumer-electronics-obsessed management got the idea from that they should drop all kits. I have no doubt that it won't be long before they stop selling components too.
                      There are two hobbyist companies down here who are going to be ecstatic that DSE is out of the kits business. Lots more sales for them! I'm hoping that one of them will take over making the ESR meter kits.
                        on the bananna jack issues.
                        i retension the plug(male) and apply deoxit.
                        radioshack discontinued the pens and i loaded up on them.
                        i find most of the inaccuracy reported in this unit is high contact resistance in test leads and jack/plug.
                        all 6 of mine have been excellent.
                        care must be taken during calibration though.
                          Thats exactly what I am going to do. I did notice the contact area on the male ends as recieved is a little small. A few tweaks with a screwdriver and they will be better than new.
                            My meter is all closed up now and works fine. These little single-layer boards seem to give me trouble - I burned some of the pads and had to patch them with wire. I've only soldered on a little board like this once before, and that was on one of those generic Radio Shack PCB's you can buy for $1.79. It's been long enough since then that I was out of practice (not that I got much practice even then).
                            Kind of embarrassing to show all my mistakes, but maybe I hit some caveats that others may benefit from reading.
                            I'm disappointed with the flaws, but I always have to do something 2-3 times before I get it right. If I were to build one of these again it would come out better I'm sure.
                            I noticed about 3 or 4 ruined pads along the way, and repaired them with wire.
                            I used a machine pin socket on the 28-pin, but only because I happened to have one. I wanted to use machined 16 and 18-pin sockets for the IC's, but I didn't have the right sizes.
                            I used a HeathKit variable DC power supply which I recently bought from a Goodwill store (lucky find). It has a built in ammeter so that was convenient for the first test. Unfortunately, it also has a built in current limiter, and in my inexperience I had it set too low. My first attempts to start the meter showed no current draw and nonexistent IC voltages, so I started tracing the circuit to find the problem. There wasn't one - after I tried raising the limit it started right up. Voltages were fine, so I installed the chips.
                            At this point I didn't have the button connected yet, so I was holding the wires together to start the diagnostic. It didn't seem to work, so again I started tracing the circuit. Turns out the diagnostic won't run unless you hold the button on the FIRST try. After that it won't enter diag mode. Since I wasn't holding the wires together perfectly enough, it looked like the diagnostic wasn't running but I eventually realized it worked fine. I got the expected .8.8 result. I see no reason why the diagnostic shouldn't work on subsequent attempts to hold the button - that's one change I'd suggest if Mr. Parker ever decides to reprogram it.
                            Fast forward a bit, I was starting to play with the probes and noticed how hard it was to get a stable reading. The meter shut off whenever I tried to zero it, because the resistance was too high. The jacks were fine though, as the meter worked very well with items stuck into the jacks directly. I ended up soldering directly to the PCB, but I'm not sure that made much difference. I've found that I just have to squeeze the probes against each other pretty hard before zeroing them. When I measure a cap, I get good readings as long as I stab the probes into the solder with some pressure. That's understandable considering the fine measurements involved.
                            As far as strain relief (which I mentioned in my earlier post), I ended up not doing much about it. At first I tried tying the wires in a knot behind the panel, but there wasn't really enough room to squeeze that in. I accidentally wrapped one wire around the other when I soldered them, so they are somewhat crossed on each other anyhow. They seem to snag on each other more than the PCB, so I'm not worried unless the probes get yanked pretty hard.
                            My final error (last one, I promise) was with the red filter installation. I used superglue to install it, and it started to squeeze out on the top cover. I grabbed the first thing I could find to wipe up the mess before it dried, and that thing was alcohol. It wiped out the cover markings pretty easily, so I now have a "E--__ter". Oh well, it works just the same no matter how it looks. I've already diagnosed bad surface mount caps on a board that I otherwise would have only been able to guess about. Great tool.
                              Re: Bob Parker ESR Meters
                              Spacedye69, here is what kc8adu was referring too http://www.caig.com/ I use both the Deoxit and Pro-Gold (no longer avalible in the nail polish like bottle). If just a touch is used on batteries their life is extended to a noticable degree, cell phones, digi-cams, any dry cells and I use it on test leads also. Very little goes a long way.
                              Hi Bob Parker *tips hat*.
                                The function of the button when the power is already on is to zero the meter if the probes are shorted (< 1 ohm resistance) or turn the meter off (=> 1 ohm). It made more sense for the microcontroller to watch for the button being pushed for 5 seconds only at initial power-up, not in the middle of normal operation. The self-test function is something you should never need once the meter's built and working, and I didn't want people accidentally triggering it. That's why I did it that way.
                                Glad you got the meter working OK and I hope it will be very useful.
                                  Sadly, since Dick Smith sold off his interests in the electronics store chain they seem to have gradually moved away from the electronics professional/enthusiast/hobbyist client focus to that of general consumerism, it's really quite a shame as I've been a regular customer since 1983 and have found myself having to source more and more components from alternative sources
                                  Additionally, a once well padded technical/data section in the catalogues has been put on a serious diet
                                  * applauds forum members on completing their kits... looks ashamedly at unfinished project *
                                  Viva LA Retro!
                                    All is well! I tweaked the tension inthe plugs, wire brushed the plugs ans tips, and cleaned it all with brake cleaner. Worke perfect.
                                      Excellent! Just be careful with that brake cleaner ... the stuff I've used attacks most plastics in a big way.
                                        Wow
                                        I am not here and look whats happened!
                                        Welcome Bob and thank you for your input
                                        RE the quality post yeah I was scratching my head on that one...
                                        But thought I would post it, since they mentioned it
                                        For others too form there own opinion....
                                        As to the probe yeah doh! sometimes you miss the obvious thing to do.
                                        Just lately the quality of cheap stuff has been not good and why I recommended better quality probes or plugs.
                                        I thought later after id posted
                                        I should have made it clear about the meter and contact resistance.
                                        gdement don't worry mate we all start somewhere and this is why we have forums to help each other and learn so thanks for your posts and input.
                                        As to DS yeah ....not sure if I put this in the post, maybe a pm but its become somewhat of a supermarket....and that was my suspicion..."'to drop all kits"
                                        The range of parts and kits has been growing less and less as the years roll on
                                        We still have 2 that cater to the electronics enthusiasts in Australia.
                                        ( and that was my other thought Bob although I didn't mention it)
                                        Cheers all
                                          ok just had a look with the supplied leads yeah bit wobbly and contact on the probs is not great either
                                          so this would defiantly apply as a procedure to do as part of the construction process me thinks
                                          if you are going to use the supplied leads
                                          Just beware as pointed out above some cleaning solvents will destroy plastic as soon as look at it,
                                          other stuff will break it down over time so use the recommend is my advise.
                                          Now excuse me while I go myself over the head for not thinking of this when I first posted
                                          Cheers all
                                          gdement I've PMed you please respond when you can thank you
