I got today 4 GV-NX66128DP cards for free that seem to have the same problems.
They are based on GeForce 6600 VPU and they use passive cooling...
In 2 of 4 cards there are some caps bulging. The bulging caps are 1500uF 6.3V KZJ. What is the maker of these caps? Are they quality ones or not? Why they failed?
1 of the 2 cards without bulging caps has 1500uF 6.3V Rubycon MBZ instead of KZJ.
At the back side of the cards there are signs of liquid... I didn't have a clue what this could be until I read this:
"Silent-Pipe Technology
Fast heat spreading without a sound: Heat pipe is filled with liquid material to transmit the heat generated from the heat source side: GPU side, to the other side of a graphic card. Heat is to be brought by vaporized liquid to the other side of the pipe, then for capillarity force, water from cooled steam will go back to the heat source side to begin its thermal trip again, hence, Silent-Pipe enables a graphic card to run quiet and fast to meet the needs of users who has a preference for tranquility at work."
Well, it seems it's not filled anymore LOL
Now what I can do to repair these cards? Should I clean up the boards from liquid and then test them in a motherboard to see if they work?
Photos of every card's up and down side attached...
