Need a bios dump for Lenovo Thinkpad X1 carbon. thanks
Lenove Thinkapd X1 carbon bios dump
Re: Lenove Thinkapd X1 carbon bios dump
That is another issue but currently the system is complete dead only power led blink three time then nothing and another technician write the bios with wrong file.
i search on google and i found a BIN file for same model but that is 16MB and the eprom is 8MB as i attached below.Attached Files
@dycc i write your provided file 8MB the result is now power on^off OK, keyboard lights OK
Function keys touch panel ok but the problem is no display.
i also download another dumps from a Russian forum on that is different symptoms power on that dumps power on ok but shut down after two mints and no display.
i am confused that this board is 8MB or 16MB bios the board complete ID is Lenovo Thinkpad X1 Carbon LMQ-1 MB 12298-2 48.4LY07.021 .
Originally posted by deemoon View Postthraj this for lenovo x1 carbon LMQ-1 MB 12298-2 48.4LY06.021
Hi Working Lenovo x1 carbon 16 mb fileAttached Files
Originally posted by azanwaqas View PostNeed bios x1 carbon 6th gen 142p16.002m82-2m lrv1 mb 448.04
I found the BIOS chip (mxic 25l6475e) and took it off the board, which was very difficult. The solder would just not melt. So I soldered the points with a soldering iron to help try loosen up the solder. It worked but it was touch and go there for a while.
Read in the old BIOS successfully without any problems, but having problems writing back to the chip with the replacement BIOS. It seems to finish fully but pops up with an error saying "Programming Stopped". gonna try on another workstation in case there are USB issues. Fingers crossed.
Originally posted by dycc View Postif you are just looking for it to remove SVP just give up . password is not stored inside SPI rom.
Hello, I have a lenov x1 carbon password bios, how to unlock it? flash bios will not work because the password is not stored in the eeprom bios? thank you for helping me
Originally posted by Gobbla View Posthow to remove pass on bios for that model ???
thx
bios flasing did not help :/
