Hi All,
We've got a HP Pavillion X360 14-DW1008TU with a mainboard number of LAIKA-6050A3202801-MB-A02.
Does anyone have the exact schematic to this? There are a few on bad caps but they seem to be different revisions as none of the silk-screening part numbers match up. I've also checked Xin Zhi Zao and they also do not have a exact match. Only one they have is FAROE DIS X32 and again the board view looks similar but not the same and none of the part numbers match.
Anyway, going off the silk screening on the board L60300 is reading low, 0.025 diode mode 36.8 resistance mode. Also L66020 0.054 diode mode and 69.4 resistance mode. L60300 is near the power button and L66020 is near the EDP & touch pad sensor. There the only abnormal readings I could find. Physical inspection yielded nothing, some discolored parts but nothing reads abnormal, and nothing looks damaged. DC In jack connector itself reads fine but 1 capacitor under the connector is reading short on pin 2, and checking resistance mode between it and L60300 is only 30 ohms so I'm suspecting that's why but without any proper documentation it's difficult to be definitive.
Is there anything else I should be checking before hooking up the charger and start looking for heat? I've already checked DC input isn't shorted to the CPU for a change so that's not a concern.
Thanks for your assistance.
