Working a Samsung UN32M530DAFXZA no backlight, flashlight test OK - manufacturing date July 2017.
When evaluating the LED strips with the low current tester one strip fluctuates a bit going from about 18.3 volts to 23 volts. I suspect this is the strip causing the shutdown.
After pulling the screen and looking at them, it looks like the part labeled "W1" is the problem. On the good strip it measures a short. On the questionable strip it seems to check like a diode?
The part next to it appears to be a zener diode and there is one for each LED, but only one "W1" that is in series with the + supply line.
Any thoughts on what "W1" might be
PS - the screwless rear cover took what i would consider an extreme force to release the clips on the top - it is different than the sides as the top part of the bezel wraps around at the top of the set.
Thanks for any comments
