tda1085 & triac problem
    Hi
    I have a problem with a tda1085c circuit.
    The board has 2 terminal switch with a moving shaft.There are 3 positions. Position 0(motor stopped) posistion 1(right-handed rotation) and position 3(left-handed rotation).At the same time, moving with the shaft a potentiometer to adjust the speed.
    if it has been pressed position 1 or 2 and after turn on the main power switch(230v), everything is ok with universal motor.
    If i turn on the main power switch and press the terminal switch from position 0 to position 1 or 2 the motor starts with high speed and stabilizes in the right speed.The change of direction takes place with relays.
    I have tried to change the potentiometer, but the problem is with the spikes from switches and the triac(bta26-700b)
    Also i have tried to put electrolytic capacitors on switch contacts and gnd, but the problem remains.
    video : https://files.fm/u/qmtjcx3rv
    Could you help me?
    Thank you
    Re: tda1085 & triac problem
    not sure what the proper behavior should be?
    what is this motor for?
    is the high speed improper?
    Why does this control have a potentiometer on it in the first place, wouldn't it be easier to have a 3-position center off toggle switch and do away with the potentiometer?
      i dont even understand the question.
      is it blowing the triacs?
