Focusrite Saffire Pro 40 re-cap
Re: Focusrite Saffire Pro 40 re-cap
Hello everyone!
If anyone would please and be able to upload lots and lots of pictures of a Saffire Pro 40 power supply, I would be very grateful.
I bought a used device that is missing some parts.
What it does is completely different from what you see in some of the pictures on the internet.
Whats missing:
D1, D2, D3, D4, D10
C3, C11, C12, C13, C14, C15
If someone writes me a list of the value of these, that’s more than enough.
Thank you very much!Comment
How about posting a photo of your power supply first?Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - ShenanigansComment
I am in the process of recapping my power supply and wrote down the values of the original power supply caps. However, I don't know the diode values. I can check those when I have the unit out of the rack, but I may not be able to get to it for a little while.
Here are the cap values:
C3: 82uF 450V 105C
C11: 470uF 35V 85C
C12: 470uF 35V 85C
C13: 470uF 35V 85C
C14: 470uF 35V 85C
C15: 100uF 100V 85C
I hope this helps. Give me a little bit of time and I can get those diode values for you.Last edited by SolderFumes; 07-23-2020, 02:38 PM.Comment
Not sure if you're still working on your Pro 40 but I was able to get some of the diode info you requested:
D1, D2, D3, D4 are all RL207
D10 starts with FR10, i can't tell the 5th digitComment
I have been sourcing new caps for the Pro 40 power supply and the 5 CrapXons on the main board.
All the caps on the power supply are general purpose caps with no impedance data available. As a general rule, is it acceptable to replace general purpose caps with low impedance/low ESR caps of the same value? It seems that many of the better caps (highest ripple & longest life) are low Z. I see that you used some UCC LXV and Panasonic FR series (also low Z) in yours.
In other words, if I replace all the power supply caps with caps of the same value but low Z, would this likely cause any unintended, predictable consequences? Conversely, is it desirable to replace them with low Z?
The huge 82uF 450V 105C cap on the power supply is a mystery. It's made by Tianchen. Who? I can't find any data on it. There aren't many available in the same or similar size package so I'm just going with whichever can handle to most ripple and has the longest life.
The 5 Crapxons on the main board are GF series and those are already Low Z so that's seems straight forward.
If you could shed some light on this, I would appreciate it.Comment
That's great news! Congratulations. You saved a Pro 40 from the trash can.
Do you have any pics of your completed power supply?Comment
Got a second hand Pro 40, thought it could be used at least as ADAT A/D now as officially it's not supported/working with Windows 10 anymore. Anyway, it does, at least on my 20.04, and I have it connected to 1820M's FW port, the 1820M sits on PCI bus converter which connected to PCIe slot (there are no PCI slots on the motherboard).
Now the PSU is some generic one made by FEREX, model name is FP07M063. That same one is used on many (all?) Focusrite interfaces, though afaik they are planning to replace it. It's specs look like this:
Code:Brand: FEREX Model: FP07M063 Applicable Products: DVB digital TV set - top box Input voltage range: 100V-240V The output voltage: + 5, + 15V, -15V, + 51V Output Power: 10W Input characteristics Input voltage range: 100V-240V AC Input voltage frequency: 47Hz-63Hz Output characteristics Output combinations: + 5V, 2A; + 15V, 0.7A; -15V, 0.7A; +51 V, 80mA Ripple: 50mV Efficiency: 70% Min. (220V AC / Max Output Current) Dielectric strength: AC 3000V, 10mA, 60Sec Insulation resistance: 30M Min DC 500V Mean time between failures: working time 50000H Protective function: Output Overvoltage Protection (OVP) Output Short Circuit Protection (SCP) Output Overcurrent Protection (OCP)
https://www.fullcompass.com/prod/522...-mkii-rednet-1
Maybe you could get one from Focusrite directly?
Btw. The main reason for burned Dice chips was that the firewire cable bundled with the early units was faulty. Well, it may be that now the PSU are is the main reason for non working units, don't know.Comment
https://khronscave.blogspot.com/2021...-teardown.html
Replacing the caps on the secondary of the power supply should reliable-ize it for years and years, assuming you use "proper" replacements (low-ESR ones from the handful of reputable manufacturers, and from a trusted source).
Unless you spring for a custom-made Delta, LiteOn etc, i have really serious doubts you'll find a suitable / compatible power supply with Japanese caps (which, "by definition", is bound to be way more reliable and long-lasting than all these cut-rate "Shenzhen specials").
PS: Hi again; you're here too?Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - ShenanigansComment
Regarding the caps, on mine Pro 40 they have some nasty glue on them, didn't try remove it but it felt hard. Anyway, I like recycling the old gear. There are many firewire interfaces which will work forever as ADAT converters once they have been recapped and the internal mixer setup saved onto flash though not all work standalone.Comment
Totally with you on thatI have two M-Audio ProFire 2626's as extra mic inputs in my recording rack; each cost me under 100e IIRC, and replaced the two MOTU 8Pres that i sold for more than that
... But that's enough off-topic-ing
Regarding the caps, on mine Pro 40 they have some nasty glue on them, didn't try remove it but it felt hard. Anyway, I like recycling the old gear. There are many firewire interfaces which will work forever as ADAT converters once they have been recapped and the internal mixer setup saved onto flash though not all work standalone.Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - ShenanigansComment
First of all, clean off the soot (black stuff) from the bottom of the board.Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - ShenanigansComment
Well, you're somewhat in luck. I do actually have two Saffire Pro 40's that i need to put up for sale, so i suppose i could take a look under one of the power supplies in the mean time.
But until then, determining what was the root-cause of the damage would be very useful, and so would figuring out which components are blown. You can bet your life those resistors are NOT the only things that let the smoke out.
One of these two Saffires i have, turned out to have a faulty PWM controller in the power supply - the feedback side of it was wonky, so the output voltages were about twice what they should have been. I have no idea what the stock chip was, but replacing it with a pin-compatible one (and removing a now-unused resistor) cured that.
Considering that group of four parallel current-sense resistors is that well toasted, is a safe bet that the MOSFET is now just a wire, ie. shorted drain-to-source, at the very least. Probably blew the gate as well, going by the seemingly cooked 10 ohm resistor (marking "100" in the last photo), which likely killed the PWM controller as well.
There's gonna be quite a bit of measuring to do, before drawing up a list of parts that need replacing...Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - ShenanigansComment
by momakaHere’s another motherboard that needed a full recap: an ASUS P5GC-MX.
This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
So here is what the motherboard looked like with its original caps:
CPU VRM area up close…... -
by momakaI've been seeing a lot of cheap-looking (but not always so cheap) no-name AGP video cards on eBay for a while. They started popping up quite a bit when the market for AGP cards became more alive all of a sudden due to interest in “retro” PCs. One thing that struck me about these cheapo cards is that they almost always seem to come with garbage caps - including the abominable Sacon FZ. That aside, though, I've been wondering about the rest of the quality (or lack of?) on these cards. So I decided to satisfy my curiosity yet again.
This one was actually suggested to me by ChaosLegionnaire.... -
by FoetussHi all
Hope this is in the correct place.
I'm planning on recapping both motherboards. I actually already ordered recplament caps for them, where I will be changing out most for poly's.
Could use some double checking to see if I'm not doing something stupid.
Pictures of the boards are attached.
What I will be replacing with what : (planned)
Soltek Golden ::
4 1500µF 16V 10mm (5mmL) KZG => APSG160ELL152MJ16S (Chemi-Con 1500µF 16V)
6 3300µF 6.3V 10mm (5mmL) KZG => APSG160ELL272MJ20S (Chemi-Con 2700µF 16V)...2 Photos-
Channel: General Capacitor Questions & Issues
by speggio91Hi everyone,
I'm trying to repair a Focusrite Scarlett Solo 3rd Gen audio interface that was accidentally exposed to 12V on the USB-C VBUS line instead of the normal 5V. A component marked as U1 on the PCB has completely blown up together with the capacitors C17, C15.
From the teardown video linked below, it's indicated that U1 is a voltage regulator (switcher) with 6 pins. Unfortunately, the original part on my board is so damaged that I can't make out any markings or identify it.
Video Link: https://youtu.be/8onqBc5iTB4?si=KHtU772wsproFGZy&t=633...2 Photos-
Channel: Troubleshooting Audio Equipment
Got 4 CCFL 16/10 monitors for free.
The resolution is almost Full HD (1680x1050)
VGA Input only is a bummer though.
Uses cheap TN panel with terrible viewing angles.
Even though this is not 17" 5:4 screen, still has very low resell value here. Can be found for 15-20 euros.
All the 4 monitors were not working and needed psu recap. Used mix of mediocre / junk caps to recap them, then donated 3 of them to friends/relatives and kept 1 for myself. Also like to install extra caps on empty spaces to help them last longer.
Channel: Troubleshooting Computer Displays
- Loading...
- No more items.
