Toshiba Satellite - Locks up when plugged in
  • Dimitrios
    • Nov 2013
    • 127
    • Greece
    #901
    Re: Toshiba Satellite - Locks up when plugged in
    I am afraid hot air will melt also my NEC/TOKIN. How did you do this?
    • goodpsusearch
      • Oct 2009
      • 2850
      • Greece
      #902
      Either way it will last more with the 4 330uF caps solution.
      • atsio
        • Oct 2013
        • 819
        • Greece
        #903
        Use bga station. Bring preheater up to 190-195 degrees (board temperature at area of Tokin) and use hot air to remove (do not exceed 240 degrees at the tip of nozzle of hot air gun if you want to save the Tokin you want to remove).
        Use only preheater at 190-195 degrees and leaded solder to solder new Tokin.
        • Dimitrios
          • Nov 2013
          • 127
          • Greece
          #904
          Installed successfully 4x tantalum but still the same hiss noise and shutdown... Strange. Might try to replace cpu. Any suggestion?
          • rievax_60
            • May 2012
            • 897
            • australia
            #905
            What is the ESR spec of the capacitors? Is there a short circuit across the capacitors.
            • Dimitrios
              • Nov 2013
              • 127
              • Greece
              #906
              These are the caps I used. They are reporting 25mOhms ESR.
              http://www.ebay.com/itm/4x-SMD-Tanta...id%3D100148%26
              God I am so close fixing it. I checked resistance and have different values between the two positive and negative lines...
              Will take detailed measurements tomorrow with and without CPU installed.
              1) It still works perfectly with battery on and charges fine when not opened, like before
              2) the hissing disappears when I press the caps with my finger and appears to start but not booting properly and no screen at all...
              • rievax_60
                • May 2012
                • 897
                • australia
                #907
                If there is a short circuit, it would not work on battery. Maybe the capacitors are not soldered properly, that would explain the different readings on each side. Send us a photo of the area.
                • Dimitrios
                  • Nov 2013
                  • 127
                  • Greece
                  #908
                  Yeah ok will do that tomorrow morning! A very detailed report of readings plus a pic. Then I will resolder them again and hopefully I wont damage anything from excessive heat...
                  • rievax_60
                    • May 2012
                    • 897
                    • australia
                    #909
                    I hope you are not using hot air. Most of us use a temperature controlled soldering iron with a large tip. You should be able to check the continuity of the joints. Just need to keep in mind that when you press down with the probe, it could cause a bad joint to make temporary contact.
                    • Dimitrios
                      • Nov 2013
                      • 127
                      • Greece
                      #910
                      Hello! Re soldered them and turned out to be a remaining silver row plate from the old NEC/TOKIN still left below the solder so was not clearly visible. Should have cleaned it better...
                      Anyway after the resolder at the caps everything went along perfect powering the laptop with the adapter plugged in properly. I was very happy and begun to assemble the laptop. When I finished it started well but as soon as it got after the Windows (Vista) logo it restarted by itself... I tried again the same result.
                      I tried with battery only and loaded the Windows perfectly. Afterwards I plugged it in again while on and it worked for 10 minutes before it restarted itself again...
                      Any other suggestion cause it supposed to be fixed with the new Tantalum caps...
                      Here are some pics (notice the silver plate that was interrupting proper contact of caps)
                      • rievax_60
                        • May 2012
                        • 897
                        • australia
                        #911
                        I can't see all of the joints. Your iron isn't melting the solder properly. You need to look closely at where each capacitor tab is soldered to the PCB.
                        The capacitors should be ok judging by the seller's feedback.
                        Maybe someone who has used the same capacitors will comment now.
                        • goodpsusearch
                          • Oct 2009
                          • 2850
                          • Greece
                          #912
                          I too believe that the caps are not making full contact. Maybe not soldered good enough.
                          • nackgr
                            • Mar 2015
                            • 18
                            • greece
                            #913
                            Hello
                            i have 4x 330 e89 can i use them ?
                            • Dimitrios
                              • Nov 2013
                              • 127
                              • Greece
                              #914
                              I have seen the caps and are making proper contact as far as I can see with my eyes.
                              Is there a proper way to test with multimeter??
                              • rievax_60
                                • May 2012
                                • 897
                                • australia
                                #915
                                Yes, use a multimeter. The computer still seems to have the symptoms of poor Vcore filtering. If you had spares, I would have suggested adding more capacitors.
                                Judging by the experiences of others, these capacitors don't seem to mind a lot of heating.
                                • rievax_60
                                  • May 2012
                                  • 897
                                  • australia
                                  #916
                                  Originally posted by nackgr
                                  Hello
                                  Where did they come from. We need to know the ESR mainly. You can just try them if you have the proper iron. I found them easy tofit and remove with a Hakko 3.2mm chisel tip.
                                  • nackgr
                                    • Mar 2015
                                    • 18
                                    • greece
                                    #917
                                    i try them work like a charm! <3
                                    • Dimitrios
                                      • Nov 2013
                                      • 127
                                      • Greece
                                      #918
                                      Lucky you!!
                                      • speedy9348
                                        • Dec 2015
                                        • 1
                                        Hello everyone, yesterday i tried fixing my Toshiba Satellite Pro A300-1GT, so i bought some 330uF 2.5V tantalum capacitor with e12 inscription on them, from china (ebay). After i soldered them, laptop turns on, hard drive led flashes 2 times and then nothing, screen remains blank and nothing happens. I've seen that the user named: bonniedoon had the same problem with the same capacitors that are showing e12 on them and he bought good ones (showing e67 instead of e12 - from portugal) and he said those are working great, but i can't find them anywhere. If someone can help me with a source from where i can buy good capacitors (preferably from ebay) would be great.
                                        With a little delay: i wish you all a Happy new year!
                                        This is a picture from bonniedoon's post with the same bad caps i used (330 e12) from china:
                                        Link to his post: https://www.badcaps.net/forum/showpo...&postcount=800
                                        Thanks a lot! and sorry for my bad english!
                                        • Dimitrios
                                          • Nov 2013
                                          • 127
                                          • Greece
                                          #920
                                          With e12 didn't have much success! See a couple of posts on top of you.
                                          The thing it finally fixed the problem was to set minimum and maximum CPU power state(which controls the frequency) to a steady 100% and prevent it from going up and down. Beware your heat though!
                                            Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro A40-C-1P5 boardview and Satellite Pro A40-C-1P5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-06-2024, 06:10 AM
                                            Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro R50-C-17C boardview and Satellite Pro R50-C-17C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-06-2024, 05:40 AM
                                            09-06-2024, 05:27 AM
                                            Toshiba Satellite Pro Satellite Pro R50-EC-12X Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Pro Satellite Pro R50-EC-12X Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro R50-EC-12X boardview and Satellite Pro R50-EC-12X schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                            09-06-2024, 08:10 PM
