Lg 50pj550 no STBY light
  • dzyk2000
    • Jul 2018
    • 41
    • United Kingdom
    #61
    Re: Lg 50pj550 no STBY light
    Originally posted by budm
    Well, what happen when you power up board after fixing the solder joints?
    Same result. Thanks a lot for help, I have to stop because it's 2 o'clock at night and I can not be careful. Tomorrow start again. Thank you very much.
      The main key point right now is that the internal charge pump inside the IC has to charge up the cap on VCC pin to 18V for the circuit to startup. So I hope your replacement IC is good.
        Originally posted by dzyk2000
        gnd to pin 1 is more than 20Mohm or is error measure
        gnd to pin 2 is more than 20Mohm or is error measure
        gnd to pin 3 10Mohms
        gnd to pin 4 15kohm
        gnd to pin 6 2.30 Mohms
        just f302 blow up, ic still look good,
        Looking at the spec sheet, the cap will be charge up with 0.9mA current source so to get 18V, the resistance has to be at least 20K Ohms. So something is still not right at VCC pin. Right now you are are getting 0.5V so that tells me the internal charge pump is not working at all.
        • dzyk2000
          • Jul 2018
          • 41
          • United Kingdom
          #64
          I tried with 4 different ic and i have same result. I don't understand why don't open cell, i have 1,2v in ba and 0.60 in vcc
          • dzyk2000
            • Jul 2018
            • 41
            • United Kingdom
            #65
            Any idea please?
            • dzyk2000
              • Jul 2018
              • 41
              • United Kingdom
              #66
              Update:
              I found c311 burnt. I removed the capacitor and now without it I have normal standby voltages but the red LED is off . where can i find the list of smd capacitors values? on the schematic are not noted.
              I need to know the value of c311 and c310.
              P813 In stby: relay click just one time (3 sounds normal i think)
              17v pin 0v
              5.1v pin 0.69v
              er det pin 1.69/1.72v
              stby pin 3.50v
              ac det pin 0v
              m-on pin 0v
              rl-on pin 0v
              P813 With main board conected: relay clicking noise repeatedly.
              17v pin 0v /17 v when relay click
              5.1 pin 0.69 /0.72
              er det pin 1.69 / 3.72 when relay click
              stby pin 1.62 all the time
              ac det pin 0v / 3.90 when relay click
              m-on pin 0.3 all the time
              rl-on pin 1.40 all the time
              • dzyk2000
                • Jul 2018
                • 41
                • United Kingdom
                #67
                https://www.youtube.com/watch?v=UWJltRjRyZo
                • dzyk2000
                  • Jul 2018
                  • 41
                  • United Kingdom
                  #68
                  Hi again, Please i need some advice.
                  I connected the board as in the training manual with 2 bulbs of 100 watts between the vs and the ground. I made straps between rl-on / stby and m-on / stby with a 100 ohm resistor and between gnd and autognd. the bulbs illuminate for a few seconds and burn again zd 301.
                  • dzyk2000
                    • Jul 2018
                    • 41
                    • United Kingdom
                    #69
                    Up, need some help please.
                    • mmartell
                      • Oct 2013
                      • 3189
                      Not sure if this pertains to your situation or not. I just repaired a 50PJ550 by replacing a single 10 ohm power resistor that went open.
                      http://www.coppelltvrepair.com/p/639...ing-on-and-off
                      • JohnML1975
                        Panasonic TH-P65ST60A no STBY light no backlight no power
                        by JohnML1975
                        Hello All
                        Started working on this TV today
                        As I remove the back will share some photos and findings
                        The problem I am having is in the title of this thread
                        I still need to proceed my trouble shooting
                        Started a thread so that I can share with all
                        Any inputs are welcome
                        10-25-2025, 04:50 PM
                        Lithonia Lighting versus Light of America Compact Fluorescent product quality
                        by sam_sam_sam
                        I have a Lithonia Lighting 65-Watt Gray Hardwired Compact Fluorescent
                        I also have back when Light of America had these light bulbs available for yard lights
                        The issue with Light of America was the blast boards had all most certain board failure while bulbs hardly ever fail
                        While the Lithonia lighting fixture has all most certain bulb failure
                        So I have modified the Lithonia lighting fixture to accept the Light of America light bulb and see how long this will last
                        I have only had this light fixture for not more than a year if it...
                        07-02-2023, 03:45 PM
                        LG Gram Ultra-light Weight Notebook Specification for Upgrade or Repair
                        This specification for the LG Gram Ultra-light Weight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-light Weight boardview and Ultra-light Weight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                        09-07-2024, 03:40 AM
                        LG Gram Ultra-Light Laptop Notebook Specification for Upgrade or Repair
                        This specification for the LG Gram Ultra-Light Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-Light Laptop boardview and Ultra-Light Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                        09-06-2024, 09:10 PM
                        09-06-2024, 08:40 PM
