Honeywell quartz clock component
  • sofTest
    • Aug 2008
    • 361
    Re: Honeywell quartz clock component
    Originally posted by Radio Fox
    You're right. With the kind of inaccuracy you're getting, it's way beyond the fine tuning of that trimmer.
    I am wondering about the supply to the chip on that board. I assume there is a zener diode somewhere on the board, probably between the unknown component, and (what looks like) the battery. If it is a rechargable NiCad and is no longer holding a charge, then there's a good chance that one or more cells have shorted. This may be pulling the supply volts down, causing the chip to operate erratically. Just a thought.
    EDIT...btw, as Krankshaft has pointed out, this clock uses a transformerless mains supply. Be very careful if you take any readings while it is powered up!
    You are right, the diode (tests OK) is between the battery and the brown capacitor. Would it harm just removing the battery? Or is any other modifications needed then?
    Be a mensch
    • sofTest
      • Aug 2008
      • 361
      Originally posted by Wizard
      variable capacitor is open circuit and yes that can change the tuning so much. Replace it with similar from a old clock. Not rare.
      The type of components design tells me this is far older than 20. Looks like 30 years or older. Very early quartz clock.
      Cheers, Wizard
      I've got no old clocks around, and none of the boards I've got with crystals on them got a trimmer. If I were to buy a new one, what capacitance range do you recommend? Does this have anything to do with load capacitance of the crystal?
      A new clock costs USD 200+ (probably more here in Norway, haven't received the invoice yet), so a couple of dollars for components for testing will be nothing.
      Yes, you are probably right about the age.
      Be a mensch
      • Wizard
        • Mar 2008
        • 2296
        Try these you find with close same diameter. Should work. Not terribly critical.
        Cheers, Wizard
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          the glue on the trimmer is likely the problem.the stuff goes conductive and corrosive.
          yes i do rf work.no big deal to me.have 2 tm-742's apart in front of me now.i overhaul a lot of radio gear.
          • Pyr0Beast
            • Feb 2009
            • 406
            NiCad battery might act the same as a Zener diode. 2 in series do give a good 2.5V reference . Might be replaced with NiMh, however, they don't give as stable reference.
            Clock drifting behind might be also due to insufficient power to drive the clock-gear-motor, or dust in the gear. Some 'water-type' oil would do good to the gears after such a long time.
            You can see that if the pointer for seconds sometimes just twitches back and forward.
            • Wizard
              • Mar 2008
              • 2296
              #26
              Always disassemble, clean out and reassemble, oil. Can't just oil and forget, the gum is still there.
              Cheers, Wizard
              • Radio Fox
                • Jan 2010
                • 281
                Can you read the markings on the zener diode? Then we will know what voltage the chip is working at. I would leave the battery for now.
                I was trying to read the markings on the I.C. Does it say 1115A 158S. The photo isn't too clear, but that's what it looks like. I tried Googling it, but could not find anything.
                In the UK, Maplin sell those type of trimmers, but I don't think Digikey sell them. The green body one is 2 - 22pF, but it depends on the diameter as well.
                http://www.maplin.co.uk/module.aspx?moduleno=460
                ________________________________________________
                Invisible airwaves crackle with life
                Bright antennae bristle with the energy
                • Wizard
                  • Mar 2008
                  • 2296
                  #28
                  Zener is last thing you want in a battery powered clock as regulator, I think zener is for protection or to cut spikes from pulsing the coil for the motor.
                  Cheers, Wizard
                  • sofTest
                    • Aug 2008
                    • 361
                    #29
                    Cheers, Wizard
                    The gear is encapsuled, and clean. The clock doesn't have a seconds pointer either.
                    The zener is axial, yellow casing with the number 2 on it, and the manufacturer ITT. If there are other markings, it's obscured by the battery.
                    The IC reads 1115A 1585, and the logo is an e. I've tried to Google it before I started this thread, but nothing came up. Probably to old.
                    Actually, DigiKey does carry trimmers. Put in trimmer in the search field, and variable capacitors comes up as one option. The one on the board is 12 mm, but that is not available. I guess a 10 mm could be accommodated, so SG3007-ND would be a close match. I would need bottom adjustment also.
                    Also, I've reading up on crystal accuracy. The replacements I've found on DigiKey got a frequency tolerance of +/- 30 ppm or +/- 50 ppm. According to the formula found on this page, that would mean a max drift of 78 or 130 seconds a month. For the duty this clock is doing, neither would be a problem. I've also found a local source carrying a +/- 20 ppm crystal. So I'm thinking, why not put in a new crystal, and do away with the trimmer?
                    This clock is probably around 30 years old, so the quality of crystal manufacturing might not have been as good as today (I'm guessing). So that might have necessitated a trimmer. I've been looking at various boards of today with crystals, and found none with trimmers. Due to better crystals?
                    What are your thoughts? If you agree, how would you bypass the trimmer? I'm charging my Sony compact camera, so I can provide better macro pictures than my mobile phone camera later, if you like.
                    Thanks.
                    Be a mensch
                    • Radio Fox
                      • Jan 2010
                      • 281
                      ...The zener is axial, yellow casing with the number 2 on it, and the manufacturer ITT. If there are other markings, it's obscured by the battery...
                      There should be other markings to indicate it's voltage. The reason I asked is that I would be tempted to replace the electrolytic you had previously removed, & power it up again to measure the supply to pin 1 of the chip.
                      ...The IC reads 1115A 1585, and the logo is an e. I've tried to Google it before I started this thread, but nothing came up. Probably to old...
                      Yep, I couldn't find anything either.
                      ...Actually, DigiKey does carry trimmers. Put in trimmer in the search field, and variable capacitors comes up as one option. The one on the board is 12 mm, but that is not available. I guess a 10 mm could be accommodated, so SG3007-ND would be a close match. I would need bottom adjustment also...
                      Ahh..that's why I didn't see them. When I searched for them I filtered for "through hole" mounting, and "top adjustment". All the ones I have ever bought have been top adjustment only. The digikey ones are also bottom adjusting.
                      ...Also, I've reading up on crystal accuracy. The replacements I've found on DigiKey got a frequency tolerance of +/- 30 ppm or +/- 50 ppm. According to the formula found on this page, that would mean a max drift of 78 or 130 seconds a month. For the duty this clock is doing, neither would be a problem. I've also found a local source carrying a +/- 20 ppm crystal. So I'm thinking, why not put in a new crystal, and do away with the trimmer?
                      Thanks.
                      The problem with removing the trimmer from the circuit, is that the quoted ppm figures only apply if the correct load capacitance is present on the circuit the crystal is connected to. There is no way to determine this exactly, hence the trimmer. If you did want to get rid of the trimmer, you would have to replace it with a low value fixed capacitor (say 5p6 - 10p).
                      Zener is last thing you want in a battery powered clock as regulator, I think zener is for protection or to cut spikes from pulsing the coil for the motor...
                      Well it looks like the battery is only for backup, the usual supply is from the transformerless mains circuit which needs the zener to regulate the supply to pin 1 of the chip.
                      • sofTest
                        • Aug 2008
                        • 361
                        #31
                        Updates (been busy elsewhere):
                        The IC is an Eurosil 1115A with properties (full datasheet not found):
                        http://www.mikrocontroller.net/topic/60893 -> Google translation
                        Also, I've found two threads in German (this is a German made clock), with same or similar design:
                        http://www.mikrocontroller.net/topic/153596 -> Google translation
                        http://www.mikrocontroller.net/topic/87453 -> Google translation
                        Both concluding with the most common failure is a bad battery. Since the battery on mine is dead, the battery issue need to be resolved before any more testing can be done.
                        I've got three options:
                        1. Get hold of an 1.2V 14x17 mm NiCd battery with solder pads (not easy, but possible, in Norway (any more))
                        2. Use an 1.2V NiMH battery. Easily obtainable.
                        3. In the German threads, there is a reference to use a Goldcap (I'm guessing a Panasonic Gold Cap backup capacitor), with a LED as a limiter. I can't easily get hold of backup capacitors of a specification of a few uFs, with the space restrictions of my clock, so not very feasible.
                        So my question is, what downside would there be to use a NiMH battery?
                        Thanks for your patience.
                        Be a mensch
                        • Krankshaft
                          • Jan 2007
                          • 2328
                          Technically those are called super capacitors gold cap is just a brand name.
                          Super caps last longer then batteries, don't contain toxic metals and charge rapidly. Unlike standard lytics they are in the farad range while filters are in the uF range.
                          They're usually used for their long life for example one of my digital thermostats has a supercap in it to retain the clock and programmable settings during a power failure.
                          To use a Nimh you would need to assess it's output voltage and current. Is it printed somewhere on the top or bottom? If it is everything will be fine.
                          • sofTest
                            • Aug 2008
                            • 361
                            #33
                            Do you mean the new or old one? Of the old one, nothing is known, but from the links I found, it's 1,2V NiCd, probably 150-180 mAh. If new, two NiMH candidates that fits physically are:
                            http://www1.elfa.se/elfa~no_no/go.js...no&i=69-313-07
                            http://www1.elfa.se/elfa~no_no/go.js...no&i=69-313-15
                            Full data sheet found under the tab Dokumenter.
                            I'm also wondering about Pyr0Beast comment:
                            Be a mensch
                            • Krankshaft
                              • Jan 2007
                              • 2328
                              I don't know what he meant by stable reference but we're dealing with 30 year old tech here if that's what was there then that's what can go back without any problems. I know it's not Ni Mh because they didn't even exist in consumer products till 89.
                              If you have a datasheet for the IC I'm sure it will specify it's supply voltage an extra volt probably won't matter. As for current you'll have to defer to the posts in those other forums or the datasheet of the IC for that.
                                • 31087
                                supercap's can leak - they always do in the xbox.
                                • Pyr0Beast
                                  • Feb 2009
                                  • 406
                                  #36
                                  Goldcap would be a good choice. I got a hold of 10F 2.5V ones. They work excellent and are a good replacement for batteries. However, they don't come even close with their capacitance. Also, they do not provide any voltage limiting and any excess voltage would lead to their internal faliure (open circuit). Also, they do not 'waste' any energy so current regulating circuit would probably produce higher than normal voltage.
                                  Supercaps can be killed, esp. in VCR's.
                                  You could zap the current battery (to burn any filaments inside which are causing the short) and charge it with a couple of mA untill it is full. Unsolder it first of course. NiCad's can last 'forever' if they are of good quality.
                                  More of a warning. NiMh would work (theoretically), but has half the life of NiCd
                                  Those are the ordinary caps.
                                    • 31087
                                    check the end of the nicad to see if it's flowered - white powder escaping.
                                    that's alkaline and very corosive, so if it's powdered you need to bin it fast.
                                    • Pyr0Beast
                                      • Feb 2009
                                      • 406
                                      #38
                                      KOH - alkaline is corrosive. However once it has contact with air it will absorb any CO2 in it and neutralize itself into white powder which is harmless.
                                      • kc8adu
                                        • Nov 2003
                                        • 8832
                                        • U.S.A!
                                        #39
                                        i have seen them leak fast enough to eat up a board.
                                        had a journey video game where the battery leak got under and into a 12 pin molex that carried among other things the remote sense lines for the power supply.
                                        the guy i got it from replaced every part of the power supply.+5 would still drift.the game would run fine if you chased it with a vom and screwdriver.
                                        desoldered the molex and cleaned up the mess once i traced it down to a rs issue.
                                        and hardly a week goes by where i dont see a newall dp7 with among other issues a leaking nicad.they can make quite a corroded mess.
                                        • Radio Fox
                                          • Jan 2010
                                          • 281
                                          Looks like the guys on the German forums came to the same conclusion as my earlier post. A transformerless PSU cannot supply much current, so it doesn't take much for the supply volts to drop if a component goes faulty. Although I initially assumed that the battery consisted of a series of button cells, it looks like it is just a single 1/3 AA cell. In which case, the cell cannot be short circuit, as it would have stopped the clock completely.
                                          I dont think a supercap is suitable for this situation. Firstly the capacity of a supercap is only a fraction of that of a battery. A 10H supercap @ 1.2V has an energy capacity of just 7.2 Joules. A 250mAH battery has an energy capacity of 1080 Joules. Looking at a few dimensions, it looks like a 10H supercap might be physically too big anyway. A supercap of similar dimensions to the existing battery would be about 3.3H (just 2.52 Joules).
                                          Also, a supercap would discharge at an exponential rate. As soon as the circuit started to draw current, the voltage would drop quite quickly, and continue to drop. As we don't know the supply limits for the chip, it could stop working very quickly once it started to discharge the supercap.
                                          I would opt for the NiMH battery, that's if you actually need a backup battery. I cant see why the circuit shouldn't work without it, as the zener is directly across the supply pins of the chip.
                                          btw...why has my sig stopped showing?
                                          • shelby5041
                                            clock radio / radio lifespan?
                                            by shelby5041
                                            hi
                                            ive got a modern digital clock radio approx 15yrs old
                                            my question is how long can a clock radio or a simple radio last ss farcas operating hours?
                                            since elec components have limited hour lifecspan i would imagine the radio or clock radio would eventually fail.
                                            the reason i ask is because i have my clock radio on radio function 24/7 for the past 7 years and its still working fine....i leave the radio on ..never turn off past 7years...thats approx 60000 hours
                                            it uses very little power just a few watts i would imagine that may have something...
                                            09-14-2024, 03:30 AM
                                          • pc_okay
                                            Crystal compatibility 32khz ASUS UX325 NB255_PCB_MB_V4
                                            by pc_okay
                                            Hello friends,
                                            Its been a while, i wish you an happy new year 2025 !
                                            I have this laptop doesn't start, power light up a second when pluging USB-C charger.
                                            Laptop take 0.11A.
                                            All signals and voltages before SLP_S4# are OK but no SLP_S4# , S3...
                                            I get no oscilation on XTAL 32.768 KHZ
                                            Battery is not charging but charging led is here.
                                            PCH heat at 30° approximatively. (with no heatsink)
                                            I think this crystal might be dead, i have only boardview giving me this: XTAL 32.768KHZ 12.5PF/20PPM.
                                            It's a 2 pins Crystal.
                                            01-13-2025, 09:26 AM
                                          • UserXP
                                            Vintage SONY Digital Clock Radio ICF-C12W no audio
                                            by UserXP
                                            Dear all,
                                            I have this old radio clock by Sony from the early 80s, I guess. The clock display works, but is dim, the function board appears to be OK - but the radio unit shows no signs of life. It doesn't produce a single noise, crack or anything from either FM or AM band. It's like it doesn't even power up.
                                            i opened the radio and it is full of some TRACON gray capacitors. They only have their negative strip printed, voltage and capacitace markings - no series, no temperature marking, nothing else.
                                            My question is, do you know of this brand of capacitors and how bad are...
                                            07-21-2025, 08:35 AM
                                          • TinkerTron
                                            Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                                            by TinkerTron
                                            Hey everyone,
                                            I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                                            Instead, here's what's been bugging me so far:
                                            The schematic...
                                            03-06-2025, 02:03 PM
                                          • Fontana
                                            71R-H14BW6-T830, clock stops when shutdown
                                            by Fontana
                                            Hi!
                                            Funny problem. I have a board, model 71r-h14bw6-t830, it's a shuttle board used commonly on a lot of cheap laptops/AIOs.
                                            The clock (RTC) is not working when the machine is turned off. Doesn't matter if it is connected to dc power or not. When the PC is powered on, the clock works fine.
                                            I tried replacing Y6 and Y7 (picture below), but it doesn't seem to be an oscillator problem.
                                            I don't have the exact schematic for this board, but I'll provide one that is similar (a variation of the same board).
                                            Any suggestions?
                                            OBS: when the pc is off,...
                                            09-28-2022, 09:57 AM
