Panasonic TC-P46ST30 Fixed SC Board But Still Have a Display Issue
  • aaronwt6
    • Apr 2013
    • 855
    • US
    Re: Panasonic TC-P46ST30 Fixed SC Board But Still Have a Display Issue
    Ok. I'll begin wherever you suggest this evening on testing. Sure wish I had an extra set of parts to throw at it right about now.
    • tw2005
      • Oct 2011
      • 6458
      Obvious question but those tabs heated up enough to have soldered correctly back onto the board?
      • aaronwt6
        • Apr 2013
        • 855
        • US
        I believe so. I could reheat them. One of the diodes seemed like it didn't want the solder to flow under it as well but it was certainly stuck. I had my iron turned up all the way so it was quite hot.
        • tw2005
          • Oct 2011
          • 6458
          yeah , well it's a bugger. Was exact same SC I did for 50" , only the 4 IGBTs were bad, I left the rest,
          • aaronwt6
            • Apr 2013
            • 855
            • US
            I'll check my voltages this evening on everything and re-heat all those just in case. If you had to just take a shot in the dark would your guess be that the SC still has additional issues? I really feel like the possibility of the SS being bad too at the same time is slim. I'm tempted to just order another SC so I can have a shot at this thing running by next Tuesday then troubleshooting the board this evening.
            Not sure if you'll be around in 11-12 hours but that's when I'd have time. I know you hang out here frequently. Again, I really appreciate your time and hope I can get somewhere with it later today.
            Thanks again,
            Aaron
            • aaronwt6
              • Apr 2013
              • 855
              • US
              #26
              And yes, I think D401 and D421 were ok but I changed them out since I had the parts and it was recommended.
              • tw2005
                • Oct 2011
                • 6458
                Thanks again,
                Aaron
                probably an area for a CRO and that's more tom's speciality. If a voltage was out enough it would trip. Try the test patterns and see if any seemed 100% normal..
                Did this have loose screws and burn marks?
                All the earth points were cleaned up , new screws and maybe some reflow of the earth points underside of the SC?
                • aaronwt6
                  • Apr 2013
                  • 855
                  • US
                  #28
                  Nearly every screw on all the boards needed a 1/4 turn to snug them up. Same as my 55" version of the same TV that I have in my living room. I repaired that SC board a little over a year ago, tightened all the screws, and have been watching it since. Both it and this 46" were described as briefly having the buzzing sound before they quit.
                  I did not do anything as far as cleaning the ground points but I did add lock washers to the screws on the SC board and buffers.
                  Oh, and no burn marks anywhere that I could see.
                  • tw2005
                    • Oct 2011
                    • 6458
                    Yeah , well I cleaned mine up and added solder. Some were pretty dodgy with no solder left and black. I put all the pics in my thread.
                    • aaronwt6
                      • Apr 2013
                      • 855
                      • US
                      #30
                      I'll take a look at that and do as you suggest this evening as well as reheat the tabs on everything I installed. Will post back with updates.
                      • aaronwt6
                        • Apr 2013
                        • 855
                        • US
                        #31
                        I took the board back out and checked all the ground connections. A few were sketchy but I don't think they were affecting anything. Cleaned those up and added solder to them. I checked Vs and it's 220V. This seems high to me but I haven't worked on a plasma this new and there's no label on the panel. Tom, if you get on here please let me know what if any other voltages I should check. I may get another board on the way for backup just in case. Assuming that the problem actually still lies in the SC board.
                          220V is really quite high for a panel like this. (Panel response is quite nonlinear so going up by just 10V can have a huge effect.) And I have heard that high Vsus can cause blue and green sparkles. Try dropping Vsus to about 205V ~ 210V.
                          The best way to adjust Vsus is full white: Put a full white pattern up, and adjust it down until you see one of a few things:
                          - Dead/misfiring/intermittent pixels
                          - Pink banding on the screen (may flicker slightly)
                          - Unevenness to the white level, such as a light grey band
                          At that point, add 2V and call that the final voltage.
                          • aaronwt6
                            • Apr 2013
                            • 855
                            • US
                            #33
                            Let me get you a few pics real quick. I'm unsure which pot is Vs. There are at least two and I don't think they are labeled that way.
                              Panasonic call it Vsus (Voltage Sustain)
                              • aaronwt6
                                • Apr 2013
                                • 855
                                • US
                                #35
                                I believe these should be adequate. I see two. Both on the right side of the board.
                                • aaronwt6
                                  • Apr 2013
                                  • 855
                                  • US
                                  #36
                                  Yeah. I knew that about Vsus but I'm used to the LGs with the Pot labeled.
                                  • aaronwt6
                                    • Apr 2013
                                    • 855
                                    • US
                                    #37
                                    I think it's got to be VR251 near the bop of the board by the connector to the SS board bunt I want to be sure.
                                    • aaronwt6
                                      • Apr 2013
                                      • 855
                                      • US
                                      #38
                                      You're a genius Tom as usual. I dropped the voltage down to just 216 and it cleared up. At 211 it started looking rough again so I settled at 213 and it is perfect. I'll take some pictures after I get my son to bed in a bit. I would have never thought a few volts could make that much difference. Not to mention they were factory set and the TV is only a few years old with less than 2 of actual use on it.
                                      • aaronwt6
                                        • Apr 2013
                                        • 855
                                        • US
                                        #39
                                        Thanks again for the advice / guidance.
                                        • tw2005
                                          • Oct 2011
                                          • 6458
                                          Interesting it needed adjustment if the seal was unbroken. what is Vsus set to in the service menu? Mine is set to low. Mind you I changed mine to high and barely any difference.
                                          Anyway glad you got it sorted
