Magnavox 46ME313V/F7 powers on and off
    Re: Magnavox 46ME313V/F7 powers on and off
    OK, that does not make sense, the 56 ohms resistor is fed to pin 3 of the IR BUT YOU READ 268 Ohms.
    To get 56 Ohms to gorund between the pin 1 of the connector and ground, it must have faulty part some where, the on one I can see will be C4054. Check the resistance of that cap and remove it if it still shows < 100 Ohms.
    • cory1108
      • Oct 2014
      • 16
      • usa
      4051 and 4056 showing between 6.5 and 7 ohms but from the best of my testing the ir sensor does appear to be shorted
      • cory1108
        • Oct 2014
        • 16
        • usa
        C 4054 is 62 ohms
        • cory1108
          • Oct 2014
          • 16
          • usa
          Thank you for taking the time to help me with this! I do not have any replacement parts but it seems we have it pretty well narrowed down to the ir board so I'm just going to replace entire board.... $10 on SJ so not bad at all.
            OK, for $10 it will be cheaper than buying all the tools to fix the board, just make sure to give us the follow-up on the repair.
            • HiDesertRat
              • Oct 2014
              • 25
              With my IR board out. Measuring resistance black lead on pin 7; every pin, 1,2,3,4,5,6,8 and 9 all read an open (using 2000 ohm setting)
              I did swap the leads just to see if it would make a difference:
              pin 1 = 372
              pin 2, 3, 4 = open
              pin 5 = 1725
              pin 6 = 840
              pin 8 = 706
              pin 9 = 706
              Only did this to prove you have to have the black lead on ground when making the resistance readings. I am sure there is a diode in there somewhere that gets forward biased with leads reversed.
              Still didn't get the reading Cory did.
              • HiDesertRat
                • Oct 2014
                • 25
                Well, Cory.....how did the IR board replacement work out for you? I'm interested in knowing how things went......
                • Dbmwhite
                  • Feb 2016
                  • 3
                  hello guys I am new here. I have a Magnavox 46me313v/f7 it quit working one day. I found online some info and some stuff to check. need less to say I got a IR sensor and I installed it. the tv turn on and work just fine but then when I turn the tv off it will not turn back on. I then took the ack off the tv and I found when I unplug the ir sensor and plug the old one back the tv will come back on but when the tv is turn off it will not turn back till you unplug the ir sensor.please help
                  • heavymachines
                    • Mar 2011
                    • 1028
                    OK guys an update to this thread since the OP never came back . I removed C4056 and C4051 on IR board and tv will turn on by power switch and work fine and dandy. The ir is definitely shorted so i will be replacing it and should solve this TV problem.
                    Well after playing around the darn remote still works with tv even with those caps removed!!!!!! every function appears to work like normal i do not understand it but i will take it. Everything works.
                    • heavymachines
                      • Mar 2011
                      • 1028
                      Another update replaced those SMD ceramics on ir board and all still is well the tv works fine with or without them as long as you remove the shorted cap with 6.5 ohms of resistance...
                      • dskall
                        • Oct 2016
                        • 2905
                        • usa
                        #31
                        So was ir sensor or caps?
                        • heavymachines
                          • Mar 2011
                          • 1028
                          SMD Ceramic cap with 6.5 ohms of resistance was the culprit... Replace or remove and tv works fine either way...
                          • tonybig10
                            Magnavox MDR515H/F7 And Magnavox MDR537H/F7
                            by tonybig10
                            Hi is any one can help me on getting the Schematics for Magnavox MDR515H/F7 And Magnavox MDR537H/F7 PDF file thank you I really appreciate it. Just need to change some component on
                            the main board and the power supply board. I looked all over for the internet and I cannot find the Schematics sheet for both of them. I don't know where else to look I hope someone can help me...
                            03-07-2025, 01:03 PM
                          • a316
                            a2442 820-02098 usb-c begin charge only after reboot, until first disconnect
                            by a316
                            briefly, one usb-c port, when connect when OS running, or in recovery mode, stays on 5v and 000 amp. If I reboot ( or connect usb-c on shutdown state), it makes 20v andbegins charging, until first disconnect/connect.
                            *** on shutdown state, it makes 20v, charging stops after 4-6 seconds in rare case,, sometimes never stops. If not disconnect, it stay on 20v and charges even after OS boot. after disconnect/connect (ON state) it always stays 5v 000 amp
                            it is not software issue, it happens only 1 port. other ports including magsafe3 is ok
                            MB was after liquid...
                            02-04-2025, 10:37 AM
                          • malogro
                            Acer Nitro 5 AN515-55-55M1 [GH51G mb] powers on, no vcc_core
                            by malogro
                            Hello all,
                            I'm stumped on this guy, so wanted to see if anyone has any further ideas:
                            Intro:
                            This is an Acer Nitro 5 AN515-55-55M1 with unknown prior history (bought "as-is" on eBay). It charges the battery and powers on from both AC adapter and battery, so I think this rules out main power issues.
                            Upon attempt to boot, it will "reboot" (meaning powers down and then powers on again) only once, and then stays stuck in a status of lights on / no post / no monitor. Powering on with fn+esc maxes out the fans on first boot attempt,...
                            04-14-2023, 04:44 PM
                          • jose6326
                            Samsung s32d850t powers off
                            by jose6326
                            Powers on as normal shows an image then powers off after 10 seconds
                            I have to unplug it from the wall and replug to get it to turn back on but then shuts off
                            No blown caps
                            I searched for this model but nothing comes up...
                            11-29-2024, 11:21 PM
                          • Topcat
                            Dell XPS 8950 Power Issue
                            by Topcat
                            A few months out of warranty and it's dead as a fart. XPS 8950 with a 12th Gen I5, 32gb DDR5 RAM and a GTX1650 GPU.....
                            Symptoms it's giving are really making a coin toss between bad motherboard and bad PSU....I'm leaning toward motherboard, but there are some strange irregularities with this piece of shit system.
                            Basic test:
                            Upon connecting power cord, system powers on by itself (no button push) for a second then powers down...and then powers back on again, I hear a relay trip inside the PSU, and then powers down again and that's it. It won't do anything else....
                            01-02-2024, 05:51 PM
