Samsung LE32R87BDX
  • anotherdude
    • Feb 2013
    • 488
    • uk
    Re: Samsung LE32R87BDX
    i gave it a run over with some flyux and a heat gun last night, it's improved somewhat
    now reboots twice and on within a minute
    • anotherdude
      • Feb 2013
      • 488
      • uk
      don't seem to be getting anywhere
      now it's 3 reboots and it's on and working
      tried pushing down on the bga chips but makes no difference only time it comes on quickly is when i apply heat
      applied more flux and reheated and it's made next to no difference, other than removing the bga chips and reballing them is there anything else anyone can suggest?
      • anotherdude
        • Feb 2013
        • 488
        • uk
        anyone any idea on how easy it is to reball one of these, seen bga reball videos online but not sure if it's even the problem
        • anotherdude
          • Feb 2013
          • 488
          • uk
          just in case anyone faces similar problems, got a main av board for £15 off ebay replaced it and now the tv is fault free
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
          • ohren
            Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
            by ohren
            I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
            I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
            The models launched in 2018 and 2019 respectively....
            09-08-2023, 05:24 PM
          • ermals
            Samsung UN55H8000AF - No Picture, Working Backlight, Replaced T-Con Board
            by ermals
            Hi all!
            I've recently run into an issue with my Samsung UN55H8000AF LED TV displaying no image. I've done quite a bit of research in terms of what could be wrong with it. Below are the steps I've taken prior to reaching out here for some assistance:
            1. I've tried replacing the T-Con board (BN95-01594A), twice and have still experienced the same issue with all the boards I've tested with.
            2. I've tried to remove one side of the ribbon cable that goes from the T-Con board to the panel and still not getting any image on left or right side.
            3. I've checked voltages...
            08-01-2022, 10:35 AM
            09-07-2024, 05:50 AM
          • Asraf Atb
            Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
            by Asraf Atb
            Hi everyone,
            Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
            Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
            I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
            01-27-2025, 05:02 PM
