Ue55mu6172uxxh, bn94-12438k
  • lotas
    • Jan 2016
    • 4830
    • Russia
    Re: Ue55mu6172uxxh, bn94-12438k
    And now try to re-read the contents of this spi flash on the programmer, most likely there will again be FF at the beginning of the dump.
    • YellowJacket
      • Dec 2020
      • 107
      • Slovakia
      Yes, lotas, now when I read the binary, its exactly the same, like before your fix. Does it mean something? Is it fixable?
      • lotas
        • Jan 2016
        • 4830
        • Russia
        You correctly need to set the status register (0x88, 0x42)
        • YellowJacket
          • Dec 2020
          • 107
          • Slovakia
          Thank you lotas, for keeping helping me. But sadly, it looks like my programmer can not set status registers ( EZP2019+ ). I have to stop now, get better programmer, and then report back.
          For now, thank you a lot for help.
          • YellowJacket
            • Dec 2020
            • 107
            • Slovakia
            So, once again, I have to thank you. I got new programmer - XGecu TL866 PLUS - and I can change even status register with it ( my old one, EZP2019+ couldn't do it ). After flashing your foxed dump, TV is working again.
            // if I can ask - how to know, which block protect bit should I set, if I have similar issue in future? I don't repair TVs mainly, but from that few pieces, what I fixed ( with eeprom issue ), I have never changed status register, and it worked anyway.
            • alex39t
              • Nov 2013
              • 51
              • greece
              #26
              iotas i want your help the tv is samsung ue49mu6202 this is bios i have read
              • lotas
                • Jan 2016
                • 4830
                • Russia
                #27
                Try your corrected dump.
                • alex39t
                  • Nov 2013
                  • 51
                  • greece
                  #28
                  iotas you are the best
                  • lotas
                    • Jan 2016
                    • 4830
                    • Russia
                    #29
                    Thank you!
                    • Matis34
                      • Oct 2022
                      • 1
                      • Poland
                      #30
                      Hi lotas,
                      i have similar problem with 25Q40 in UE55MU6172UXXH BN41-02568B.
                      I have tried your dump but still the same results.
                      In attachment my corrupted dump.
                      I would be grateful for any help.
                      • lotas
                        • Jan 2016
                        • 4830
                        • Russia
                        #31
                        Originally posted by Matis34
                        Hi lotas,
                        • alex39t
                          • Nov 2013
                          • 51
                          • greece
                          #32
                          Hi iotas good new year for you !i want your help i have a Samsung ue32t4302 it has the symptoms like the others can i send the dump to check it?
                          • lotas
                            • Jan 2016
                            • 4830
                            • Russia
                            #33
                            Hello, which motherboard is not VDM_KANT-S2_32 ?
                            • alex39t
                              • Nov 2013
                              • 51
                              • greece
                              #34
                              It is that you saying i am sure it is the 25q40 the problem i have find one dump the red light now works but no stay power up before that the board no response the red light not on
                              • alex39t
                                • Nov 2013
                                • 51
                                • greece
                                #35
                                The board it is vdm kant s2
                                • alex39t
                                  • Nov 2013
                                  • 51
                                  • greece
                                  #36
                                  this is my original dump
                                  • lotas
                                    • Jan 2016
                                    • 4830
                                    • Russia
                                    #37
                                    Try.
                                    • alex39t
                                      • Nov 2013
                                      • 51
                                      • greece
                                      #38
                                      Also i have to change the register?do you know?
                                      • lotas
                                        • Jan 2016
                                        • 4830
                                        • Russia
                                        #39
                                        Try register : 1C
                                        • alex39t
                                          • Nov 2013
                                          • 51
                                          • greece
                                          #40
                                          no sucess with this dump no red light no power.i wiill attach one dump i have found that the red light response
