Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Laptops, Portable, and Mobile Devices
Thread Tools Display Modes
Old 03-25-2020, 12:17 PM   #1
Weelcup
TopTech
City & State: Manchester
My Country: UK
I'm a: Hobbyist Tech
Default Hp omen 15-DC. 3.3v ALWS only 1.36v !!! 5v present!
Hi friends
I have omen 15-DC motherboard. 3.3V power rail only gives 1.36V !?
5V is present.
I replaced the 3.3V provider IC but same issue.
3.2v present on power button.
I also replaced super io chip but same!!
Any suggestion?
Weelcup is offline   Reply With Quote
Old 03-25-2020, 12:40 PM   #2
techtiger
City & State: paris
My Country: france
I'm a: Knowledge Seeker
Default Re: Hp omen 15-DC. 3.3v ALWS only 1.36v !!! 5v present!
Remove one Pad of coil 3ALWS and check the Voltage again, check the resistance to ground out put side of 3V line, Upload the Schematic or MB ID ?
techtiger is offline   Reply With Quote
Old 03-25-2020, 01:40 PM   #3
Weelcup
TopTech
My Country: UK
Quote:
Thanks for following up,
When rermoving one side of the 3.3v rail. There is 18.6V on the IC side of the rail.
Unfortunately, there is no schematic available for this motherboard.
The motherboard id is, DA0G3DMBCE0 Rev E.
The 3.3V ic is RT6256B.
Old 03-26-2020, 01:45 AM   #4
ktmmotocross
Boardkiller
ktmmotocross's Avatar
City & State: slovakia
My Country: slovakia
Line Voltage: 230VAC 50Hz
r u sure u measure it right?
19V on that rail will butn RT ic and all 3,3V components
ktmmotocross is offline   Reply With Quote
Old 03-26-2020, 12:21 PM   #5
Weelcup
TopTech
My Country: UK
Well, it is strange to me too. Remember, when i connect both sides of the rail it produce only 1.36v. But if i disconnect one of the rail sides, the ic side becomes 18v. I mean the rail side that gets the volt. From the ic.
Old 03-27-2020, 11:34 PM   #6
ktmmotocross
Boardkiller
rail dont get volt from chip but from step down circuit . u can have shorted high side mosfet, but that means all components on 3,3V si must be burnt
Old 03-28-2020, 11:01 AM   #7
Weelcup
TopTech
My Country: UK
Maybe, but i have checked all mosfets. Non is shorted to ground!. Besides 19v is present. 5.1v is present. Only 3.3v is missing.
I suspect the pch. Hoever, it is not shorted. I also suspect the graphic chip but not shorted as well. Soooo confusing.
Old 03-28-2020, 11:24 AM   #8
SMDFlea
Moderator
City & State: York
My Country: UK
On what pin do you have 5.1V present .The RT6256B and C have a different pinout
SMDFlea is offline   Reply With Quote
Old 03-28-2020, 11:27 AM   #9
Weelcup
TopTech
My Country: UK
Quote:
Sorry for the confusion, i was taking about the rt6256C output not B. Just to clarify that 5v is present in the abscense of 3.3v...
Old 03-28-2020, 11:43 AM   #10
SMDFlea
Moderator
City & State: York
My Country: UK
Ok start again then, post voltage for all pins and resistance to gnd .
https://www.richtek.com/assets/produ...S6256BC-02.pdf
Old 03-30-2020, 11:15 AM   #11
Weelcup
TopTech
My Country: UK
Thanks for following up. Actually i managed to find the issue.
It turned out that the charger was issue. Everthing seems to work fine after replacing the charger. Although the old charger was tested and everything thing was ok with the charger even the voltage on the middle pin was there. But it was generic180w charger.
This laptop only works with hp original charger as there were no way to get it to pass the 3.3v correctly with the generic charger. Very weired !! But this is the solution.
Thanks for everyone who advised and helped me ..
Kind regards
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2020
Powered by vBulletin ®
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
