Badcaps.net Forum
Go Back   Badcaps Forums > Motherboards with Bad Capacitors > Abit - Asus - Aopen
Thread Tools Display Modes
Old 05-12-2018, 07:57 PM   #1
Stefan Payne
City & State: Northern Germany
My Country: Germany
Line Voltage: 230VAC/50Hz or 400VAC/3P/50Hz
I'm a: Knowledge Seeker
Default ASUS A7M266 Kills T-Bred B??
I got a used A7M266 (1.04)
And tried putting in a T-Bred B from wich I was certain it still worked - and it died.
With some Measurements:
the V-Out of the CPU VRM was around 0,3V - and getting really really hot...
With a TBird it is around 1,85V and works more or less...
I tried setting the Voltage manually, didn't change anything (well, it was ~1,65V without the CPU. And also with the TBird)...
Another Thing: one of the 4V/820F Caps (those Yellow Fujitsu or so).
What can I do??
Stefan Payne is offline   Reply With Quote
Old 05-18-2018, 11:21 PM   #2
Stefan Payne
My Country: Germany
Default Re: ASUS A7M266 Kills T-Bred B??
I've desoldered those Yellowish Fujitsu Caps (4V/820F) because one looked odd.
And they measure between 1100 and 1572F wich seems a bit odd/defective...
Old 05-19-2018, 02:06 AM   #3
Agent24
I see dead caps
Agent24's Avatar
City & State: Hiding inside a plated-through hole
My Country: New Zealand
Line Voltage: 230VAC 50Hz
I'm a: Hobbyist Tech
Leaky I suppose, if it's measuring high.
__________________
-David VanHorn
Agent24 is offline   Reply With Quote
Old 05-25-2018, 10:21 PM   #4
momaka
momaka's Avatar
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
Interesting problem.
I would say replace those yellow Fujitsu caps if they are measuring high capacitance, as they might be getting leaky, as Agent24 suggested. Furthermore, when I looked for images of the board online, I found this:
https://www.anandtech.com/show/845/3
If you enlarge the picture on that site, you will see that the Fujitsu caps on that board are bulged. Makes me curious if that's due to a board design error or if Fujitsu caps like that are failure-prone (or at least the early ones).
As for replacements, you could probably use regular 6.3V electrolytics if that's all you have (Rubycon ZL or Chemicon KZE minimum). Or go with polymers again.
Old 05-26-2018, 09:25 AM   #5
Wester547
City & State: CA.
My Country: USA.
Line Voltage: 120-125VAC 60Hz.
The early Fujitsu polymers are failure prone. Back in the day, it was initially conjectured that it was because of insufficient rubber seals allowing moisture ingress which resulted in a steady increase in ESR (and eventually, said moisture evaporating to steam). Due to those high capacitance readings, though, its probably the result of residue from acidic iron compounds that are used as the oxidant for the PEDOT polymerization process. The iron particles remain in the capacitor even after polymerization, which causes leakage current to increase over time (and high leakage current usually means defects in the aluminum oxide).
The specs on those polymers should be about 5040 mA for the allowable ripple current at 105C and 12 milliohms for ESR. So, if its worthwhile to you, polymers are probably the best bet for replacements.
Wester547 is offline   Reply With Quote
Old 05-27-2018, 12:37 AM   #6
Stefan Payne
My Country: Germany
I tried and now it has the same issue (but with 0,8V) with the TBird Chip...
I used two (later 3) Panasonic FR with 2200F/10V and 470F/25V Panasonic FM.
Also used 470F/16V Polymers first.
w/o CPU its 1,7V...
Old 05-27-2018, 05:40 AM   #7
Agent24
I see dead caps
Agent24's Avatar
So maybe you have bad VID signal to the VRM controller. I get the impression you are trying to use an unsupported CPU as well?
Old 05-27-2018, 07:09 AM   #8
Stefan Payne
My Country: Germany
I can override the VID (and I did), that isn' the Problem.
W/o something in the Socket everything seems fine, though I don't have a Scope.
However when I insert a CPU (even the TBird), the voltage of the VRM is way lower than it should ant it cooks itself.
Old 05-27-2018, 04:19 PM   #9
Agent24
I see dead caps
Agent24's Avatar
What cooks itself? The CPU or the VRM?
Maybe you've managed to short both CPUs now or the VRM controller is instead\also damaged.
Did you try the CPU in another board?
Old 05-27-2018, 04:22 PM   #10
Stefan Payne
My Country: Germany
Quote:
VRM of course.
Only the defective TBred-B.
And it didn't work but voltage seemed fine, if I recall (on an MSI NF2-S Thingy)
Old 06-01-2018, 11:42 AM   #11
momaka
momaka's Avatar
My Country: U.S.A.
I guess post some pictures of the VRM area, with the PWM chip and MOSFETs. Older boards like these aren't too complex in terms of VRM design, so we may be able to figure it out. I think it's down either to a bad VRM phase (though probably no bad MOSFETs) or CPU is not getting recognized properly, and either of these could be the reason the low VRM voltage only with the CPU installed (sometimes, the PWM chip datasheet will tell whether or not that is the case).
Also, a dumb question, but since this motherboard appears to use jumper-less settings (V_core voltage and CPU frequency)... have you tried resetting the CMOS as well? Perhaps someone changed the CPU voltage and/or frequency to a value that's causing things to misbehave.
And last but not least, I see this board only supports DDR2100 and DDR1600 RAM as well as what appears to be only early Athlon/Duron chips (so possibly not Athlon XP?... though I doubt it). In any case, it's worth making sure that the RAM and CPU are compatible with the board, just to rule that out.
Old 06-01-2018, 05:54 PM   #12
Sparkey55
City & State: OK
My Country: USA
I'm a: Professional Tech
What bios version is installed 1004 or 1007?
Sparkey55 is offline   Reply With Quote
Old 06-03-2018, 06:14 PM   #13
Stefan Payne
My Country: Germany
Quote:
Goin to do that next, great Idea, forgot about that.
No, it has something we call "Mice Piano" somewhere on the Board, where you can physically set the Voltage and disable Jumper Free Mode.
Yeah, got the Board to post, then inserted the Athlon XP; saw that the MOSFETs were burnin hot...
Old 06-04-2018, 05:17 AM   #14
Sparkey55
City & State: OK
My Country: USA
What model Athlon XP CPU did you install?
What BIOS version installed?
Old 06-07-2018, 03:35 PM   #15
Sparkey55
City & State: OK
My Country: USA
Bump.
Old 06-09-2018, 10:54 PM   #16
Stefan Payne
My Country: Germany
T-Bred B, don't remember the exact model.
BIOS was the latest you could download from the ASUS Site.
Old 06-10-2018, 03:13 AM   #17
Sparkey55
City & State: OK
My Country: USA
In post #1 did you update the bios BEFORE putting in the T-bred Athlon XP cpu?
I have read elsewhere that someone did that and the cpu fried because the vrm did not have the correct VID programmed into the bios
Also inserting a cpu into a powered up board is a good way to destroy them both.
Old 06-10-2018, 03:32 AM   #18
Sparkey55
City & State: OK
My Country: USA
Asus changed the vrm design starting with PCB rev. 1.05 and above.
You state that you have rev. 1.04
That may be part of the problem.
Old 06-11-2018, 12:59 AM   #19
brethin
City & State: Owensboro, KY.
My Country: USA
Line Voltage: 120VAC 60Hz
That board doesn't support Thoroughbred CPUs,.
https://www.asus.com/us/supportonly/.../HelpDesk_CPU/
brethin is offline   Reply With Quote
Old 06-11-2018, 01:06 AM   #20
brethin
My Country: USA
A7M266-D does support Thoroughbred CPUs
https://www.asus.com/tw/support/cpu_support
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2018
Powered by vBulletin ®
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
