Thread Tools |
#1461 | |
SNES-powered
City & State: Romania
My Country: Bacau
Line Voltage: 230VAC 50Hz
I'm a: Hobbyist Tech
![]() Quote:
__________________
Main rig: ASUS H61M-A Core i3-3220 3.30GHz MSI Twinfrozr GTX 750Ti 2GB GDDR5 6GB DDR3-1066 Samsung SH-224AB DVD-RW Raidmax RX-500XT (recapped) Seagate Barracuda ES.2 ST31000340NS 1TB JNC RJA-52 case |
#1462 |
a fake rubycon
City & State: california
My Country: USA
Line Voltage: 122.5VAC 59.9Hz
![]() Last edited by ruky con; 02-23-2018 at 06:06 AM.. |
#1463 |
City & State: San Jose, CA
My Country: USA, Unsure of Planet
Line Voltage: 120VAC, 60Hz & 115VAC, 400Hz
I'm a: Professional Tech
![]() Looks like its "beef" came from Taco Bell. (Rimshot! Crash!)
__________________
PeteS in CA Power Supplies should be boring: No loud noises, no bright flashes, and no bad smells. Where might is right There is no right. - Sophocles in "Antigone" **************************** All that is gold does not glitter, Not all those who wander are lost; - J.R.R. Tolkien, The Fellowship of the Ring **************************** To kill personal responsibility, initiative or success, punish it by taxing it. To encourage irresponsibility, improvidence, dependence and failure, reward it by subsidizing it. |
#1464 | ||||
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
![]() Quote:
By the way, do you still fix/save the fans after they have seized? I certainly do. And the only reason why is because it looks like sleeve bearing fans are becoming a thing of the past now. Many manufacturers have started switching to these shitty "long life" bearing fans - i.e. *sealed* sleeve bearing fans. I HATE THOSE THINGS! ![]() At least the cheap (non-sealed) sleeve bearing fans are serviceable and actually last quite a while with a proper cleaning and good lubricant. My oldest sleeve bearing fan is going on a record for almost more than 10 years now. Granted I haven't used it 24/7 at full blast, but rather 20 to 30 minutes per day (on average per its entire life). Yet, it still spins like new. Oh man. Now the PSU you just posted before this one looks like a 10 Gigawatt powerstation. ![]() Oh, and even the fan doesn't inspire confidence with that label. Speaking of which, I've never seen H.X.S. brand before? Perhaps that was meant to foreshadow what would happen with the PSU if you use it - i.e. lots of thick black smoke pour out and pollute everything. ![]() In case anyone didn't catch what I meant above about the fan brand: I was making a reference to Hexxus from the kids movie "Ferngully". ![]() https://www.youtube.com/watch?v=hr4knvNNgtU Quote:
Or perhaps also meant to tell the slave children/workers assembling these PSUs which components to remove in case the PSU needs "fine tuning" to work stable with the undersized components. Quote:
![]() ![]() ![]() On that note, I HATE BLACK PCBs! Sorry if that sounds racist, but I really do. Same goes for any dark color PCB, actually. I really don't understand why people think it looks neat. To me it looks like the PCB burned itself to a crisp. I could easily achieve the same by dumping a bunch of coal on an old motherboard or PSU PCB and lighting it on fire. Seriously, this black PCB fad needs to go away like 5 years ago now. Quote:
![]() While still pretty overrated, at least it wasn't that terrible of a PSU for its time period. After all, PCs in 1998 and up until the Pentium 3 era ended were just not heavy power users. Unless you had over 3 or 4 HDDs and 2 ODDs connected to a PSU like that, there's no way you could blow one of these up under load. ... though that 10 Amp rectifier for the 5V rail is cutting it very close, and thus limiting the power on the 5V rail to 50 Watts max. I suppose that was enough back in the day for just about any single CPU PC. As far as I remember, GPU power consumption really didn't take off until the GeForce 4 TI / Radeon 9700 generation of GPUs came about. And a dual CPU (Pentium Pro / Pentium II) setup in 1998? HA! Ain't nobody (regular) got money for that. (Back then) ![]() Last edited by momaka; 02-23-2018 at 08:24 PM.. |
#1465 | |||||
My Country: U.S.A.
![]() Yeah, I gotta say I mostly agree with you: the soldering is pretty bad and the secondary side filtering is pretty bad. But at least the unit is not that heavily overrated, other than the 12V rail. And I do see some spots for PI coils. So this *could* *potentially* *maybe* *perhaps* be turned into a decent 150-200 Watt (continuous) power supply with the right components, if one really wanted to bother with it.
Quote:
Quote:
Quote:
But like you said, why bother with this PSU (other than having fun with it). Mine is also sitting in the closet, case-less and still partially recapped. Every once in a while when I need 320V DC to test an adapter, I use the voltage-doubler side of things on that crappy PSU to generate the 320V DC bus for me. Quote:
![]() Seriously, did this thing come with no input filter cap like that? What a POS! Perhaps the manufacturer only meant to say it's capable of 800 uA (microAmps) Quote:
ba dum tss ![]() ![]() ![]() Last edited by momaka; 02-23-2018 at 08:50 PM.. |
#1466 |
a fake rubycon
My Country: USA
![]() Rhino PSU, Model: SP-450Y 450w PC Power Supply.
I think this unit may have overheated. Label............. Looks cheap. Top Side.................. Bottom Side............................. Soldering looks bad. Primary side.......................................... There are no common mode chokes, X-class capacitors or Y-class capacitors at all The primary caps are 2 Cheng LS 470uf 200v. The primary switching transistors are two KSH13009A's. The 5VSB Mosfet is an SVF2N60F. There is a fuse, not sure how good it is though. Secondary side.............................................. ........ The capacitors are a mix of ChengX CD288H, GR, SF, and Asia'X TNX. The 3.3v rail and 5v rail both use MBR3045CT diodes. The 12v rail uses the STTH1602CT diode. The 3.3v rail has one 3300uf 10v capacitor with no PI coil. Both the 5v and 12v rails have one 2200uf 16v capacitor with no PI coil. And the fan............................................... ............................. The fan is seized up and it looks like the motor got really hot, there was also a plastic sheet in front of half the fan but I removed it before taking the photo. Overall this thing is and will always be garbage. Last edited by ruky con; 05-16-2018 at 03:12 AM.. |
#1467 |
SNES-powered
My Country: Bacau
![]() Looks like they copied a bunch of crappy brands - Raidmax for the label, Deer for the heatsinks and possibly Linkworld for the PCB design.
#1468 |
a fake rubycon
My Country: USA
![]() One odd thing i noticed is the (possibly fake/copied) UL number on the label of the Rhino PSU is identical to the UL number on the Athena Power power supply label (a unit i posted here a few months ago).
__________________
(Insert Signature Here) Last edited by ruky con; 05-16-2018 at 05:11 PM.. |
#1469 |
![]() With those heatsinks and the 470uF input lytics that might be a credible 250W PSU. 450W? Extra crispy.
#1470 | ||
"Oh, Grouchy!"
City & State: PA
My Country: USA
![]() Quote:
![]() Those always seem to be rated twice what they can barely do.
__________________
"pokemon go... to hell!" EOL it... Quote:
#1471 | ||
My Country: U.S.A.
![]() Quote:
![]() Quote:
Well said. |
#1472 |
a fake rubycon
My Country: USA
#1473 |
recapping PCB.
City & State: Gerona
My Country: España
Line Voltage: 230VAC 49Hz, 2 Ph
![]() The worst PSU I've had in my hands, a Deer, has burned resistors (with Viva and rulycons capacitors
__________________
Gaming pc: ![]() Server: ![]() HTPC: Dell Alienware aurora r3 ![]() Last edited by kevin!; 05-23-2018 at 06:22 PM.. |
#1474 |
City & State: OK
My Country: USA
![]() Sticker change time> BURNT-IN Test O.K.
#1475 |
recapping PCB.
My Country: España
#1476 |
SNES-powered
My Country: Bacau
![]() I once had the chance to buy such a Deer.
Thank god I thought twice and got a pretty beefy K-Mex. |
#1477 |
recapping PCB.
My Country: España
![]() One more:
L-LINK "500W" I imagine that L-LINK warns the buyer, if you put it at 500w, we are not responsible for the explosions caused by our product. ![]() |
#1478 |
![]() OMG! Is that beefless POS good for 200W continuous? And if it "is", which would be worse, the output ripple or the chances of transformer core saturation?
#1479 | |
My Country: U.S.A.
![]() Quote:
The burned resistors are a product of a runaway single-transistor oscillator 5VSB design (no optocoupler feedback). One of them is actually used in series with the Vcc power rail for the KA7500 / DBL494 PWM chip. So the voltage there must have been in excess of 30V for that resistor to burn. And yes, you get Viva and Rulycon caps, haha! ![]() ![]() All things considered, though... I would probably trust that Deer PSU slightly more than the L-Link above. At least the Deer has a 33 mm core transformer, somewhat better heatsinks, and "a lot more" output filtering (relatively speaking, of course ![]() ![]() And last but not least.... that CBE fan. These fans are extremely crap quality, but they have surprisingly good sleeve bearings. Once cleaned and oiled properly, they will last a long time. I used one of these as a case fan and later on as a PSU fan for a HiPro PSU that didn't have a shell/case. I haven't oiled that fan in more than 5 years, and it's still running fine (though lately it hasn't seen much use). I doubt it. Probably even 150 Watts would be a stretch with that 28 mm transformer, given that this is an old, slow-switching h-bridge design. And that's probably if you load all the rails somewhat equally. The 12V rail appears to have a 12 Amp rectifier, so that limits it to 144 Watts. I seriously doubt you'd be able to pull that much off of it before the output toroid releases the magic smoke. But with the crappy heatsinks of this unit, maybe the 12V rectifier will overheat and short-out to save the output toroid. ![]() And then just imagine the ripple on the 12V rail at that power level. Your mobo will be surfing for sure - no, not surfing the internet, but those huge voltage ripple/noise waveforms from the PSU. ![]() Last edited by momaka; 05-25-2018 at 02:04 PM.. |
#1480 | ||
recapping PCB.
My Country: España
![]() Quote:
The Deer even in spite of being a garbage of PSU, has better filtering in the lines, and inductors. Quote:
A pity that I do not have an oscilloscope, I would love to try the ripple, to see if I can one day, I will acquire an oscilloscope, I will save the PSU for when I have the oscilloscope and I will share the results in the new post hall shame ripple. I'll take advantage of that CBE, the fan barely has use. Bye ![]() Last edited by kevin!; 05-25-2018 at 05:16 PM.. |
Thread Tools | |
