Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting TVs and Video Sources
Thread Tools Display Modes
Old 03-24-2018, 11:37 PM   #101
al1415
City & State: leesville,la
My Country: usa
I'm a: Knowledge Seeker
Default Re: Vizio P502UI-B1E has no backlight, no voltage from driver board to LED's
Digi-Key Part Number 296-41938-5-ND $2.02 plus shipping usps.
Part location and info
main board U712
Manufacturer Part Number
TPS54328DDA
Description IC REG BUCK ADJ 3A SYNC 8SOPWR
al1415 is offline   Reply With Quote
Old 03-25-2018, 12:39 PM   #102
midnightg35x
City & State: Iowa
My Country: USA
I'm a: Hobbyist Tech
Quote:
Originally Posted by al1415 View Post
In the beginning on i had backlites when TV turned on, then when vizio logo go away just black screen. After plugging and unplugging and checking voltages i get only black screen and no backlites also no voltages going to T-Conn or LED driver board. On the main board their is A Synchronous Step-Down Converter location U712 Pin 2 was 1.3 volts now only .7 volts, also X201 has no voltage or the cap at connector for lvds cable to T-Conn no voltage where as before i lost backlites altogether i did have. I agree though issue is main board just what chip is the question. Could be U7612 breaking down under load maybe??
If U712 is a tps54328, pin 2 is the feedback. It should be at ~0.76V during normal operation according to the datasheet. I don't think that one is the issue. if the output voltage on that regulator is fine, I wouldn't worry about it.
midnightg35x is offline   Reply With Quote
Old 03-26-2018, 04:07 PM   #103
enzodude
City & State: bako
My Country: usa
Just another data point- Same model and problems. Replaced eeprom with shopjimmy replacement. Same.
enzodude is offline   Reply With Quote
Old 04-09-2018, 10:53 AM   #104
enzodude
City & State: bako
My Country: usa
Replace main with a used ebay board. Now it comes on with Vizio logo and than goes dead. So the no backlight problem is definitely a main board issue.
Old 04-09-2018, 04:07 PM   #105
midnightg35x
City & State: Iowa
My Country: USA
Quote:
So the ebay board changed the issue, but did not solve it?
Old 04-10-2018, 01:53 PM   #106
enzodude
City & State: bako
My Country: usa
Quote:
Yes, Original main board had no backlight at all. Replacement would come up with Viz logo than backlight would go out. Also Swapped eeproms. No change.
Old 04-10-2018, 02:18 PM   #107
budwich
City & State: Kanata Ontario
My Country: Canada
ok... so with the "new board" that gives you the logo, try disconnecting one of the tcon to panel cables and see what happens. Repeat doing the same with the other.... anything different from before?
budwich is offline   Reply With Quote
Old 04-13-2018, 01:58 PM   #108
al1415
My Country: usa
Just to throw in an update So far using leakseeker 89 I have found on main board Q210 bad which is on bottom side of board, going through downer boards that i have looking for a replacement transistor.
Old 04-14-2018, 12:39 AM   #109
midnightg35x
City & State: Iowa
My Country: USA
Looks to be a MMBT3904. Fairly common if you have spare parts or spare boards. I think I checked that particular transistor on my board with a multimeter and it was OK. I'm not sure what the leakseeker does or how well it works, so I cannot comment. On my board, it at least is not shorted because my thermal camera did not show any abnormal heat coming from it.
Old 05-01-2018, 08:40 PM   #110
BeFreeTech
City & State: Port Orange
My Country: United States
Line Voltage: 120VAC
Smile Re: Vizio P502UI-B1E has no backlight, no voltage from driver board to LED's
I have the same P502UI-B1E TV with what I think is the same problem, but I'm new at troubleshooting new TV's.. The last time I worked on them they were mostly tubes.
My TV produces no display and gives no sign of LED illumination. It has no bloated caps, or other apparent physical trouble. When I power it up with the power switch the white "standby" light fades out. Then if it's turned on again the "standby" light flashes once, pauses then flashes 16 times, then goes out.
I replaced the power supply board because I had no 5v "standby" voltage loaded or unloaded, so figured must something on the board and since the board was inexpensive ordered one, but when the new one was installed I still had no 5v standby.
I also didn't want to spend $13 for the service manual. Maybe we split it?
Could it be that this model needs no 5v standby voltage? Like you I'm seeing the 24 volts, the 12v, and the 165 volts on the power board when it's plugged in. I'm sure these questions are neophyte level, but I have to start somewhere. Thanks for any help.
BeFreeTech is offline   Reply With Quote
Old 05-02-2018, 03:46 AM   #111
dick_barton
dick_barton's Avatar
City & State: Cardiff
My Country: Wales
Line Voltage: 230V AC, 50Hz
Reading through this very long thread it appear from post #1 there is no 5v at the 5V point. Says no wire.
The checks that have been made are:-
Do you have approximately 400V across the two pins of the large capacitor on the power supply when you come out of standby
CN806
Pins 1 - 4 = 24V
Pins 5 - 8 = 0V
CN805 with backlights on
Pin 1 0V, Pin 2 = 1.5V, Pin 3 = 3.2V, Pin 4,5,6 = 0V
Pin 7 = 4.9V, Pin 8 = 4.2V, Pin 9 = 12.2V, Pin 10 No connection
On the led driver board
R8129 = 4.1V
C8067 = 1.8V
Do you have these voltages?
__________________
dick_barton is offline   Reply With Quote
Old 07-14-2018, 03:46 PM   #112
Snipeye
City & State: Utah
My Country: USA
Adding in my two cents: I've got a board that seems very similar to al1415 - I also traced that "unknown" enable signal back to the mainboard, transistor Q210 - and measured it as bad using my multimeter. I've ordered replacements from digikey, and I'll let you know if it works or not.
Snipeye is offline   Reply With Quote
Old 07-19-2018, 12:19 AM   #113
ARGO
City & State: FL
My Country: USA
I'm a: Professional Tech
I have the same tv with same problem.
I have tried to replace eeprom - didnít help.
I have tested t-con and panel by enabling test mode - panel and t-con works.
Now Iím sure that the problem in main board- it doesnít enable 12V to t-con board and backlight.
ARGO is offline   Reply With Quote
Old 07-19-2018, 12:34 AM   #114
Brucetafer
City & State: Orlando Florida
My Country: USA
I just fixed one just like this with no power to the LEDS, and it ended up being a burned out power supply and cooked the ribbon cable as well. no idea how..
D9202 D9204 D9206 were all blown out on the cold side.
Brucetafer is offline   Reply With Quote
Old 07-21-2018, 07:30 PM   #115
Snipeye
City & State: Utah
My Country: USA
Update: I’ve replaced that transistor - no effect. I forgot to test the one I took out when it was out of circuit, but it probably was fine - seeing as it made no difference. All my voltages appear fine, so I do t think it’s the power supply. I went as far as removing the panel and testing every backlight individually, and they are all fine.
At this point, I’m fairly convinced it’s the main board - but I don’t know where/why. If I hold down my power button for a while (30 seconds or so?) my indicator light blinks on/off 30 times, waits a while, then does it again. Really debating buying that service manual. I need a list of things that would cause the enable signal to not be sent...
Old 07-22-2018, 09:45 PM   #116
ARGO
City & State: FL
My Country: USA
Here is eeprom
https://www.badcaps.net/forum/showpo...&postcount=168
Old 07-30-2018, 08:15 AM   #117
Snipeye
City & State: Utah
My Country: USA
I’ve tried replacing the eeprom with one from shopJimmy’s site, are you suggesting that flashing it might work better?
Old 07-30-2018, 09:19 AM   #118
ARGO
City & State: FL
My Country: USA
Quote:
Originally Posted by Snipeye View Post
Iíve tried replacing the eeprom with one from shopJimmyís site, are you suggesting that flashing it might work better?
No, result will be the same.
I left this link for future readers...😀
Old 07-30-2018, 03:08 PM   #119
Snipeye
City & State: Utah
My Country: USA
Got it.
Is there a chance that this fault is caused by another eeprom somewhere on the mainboard, and could be fixed by flashing something other than u202? We’d need a functional one for reference...
Old 07-30-2018, 04:42 PM   #120
ARGO
City & State: FL
My Country: USA
Got it.
Is there a chance that this fault is caused by another eeprom somewhere on the mainboard, and could be fixed by flashing something other than u202? Weíd need a functional one for reference...
I have not seen any other eeprom on board.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2018
Powered by vBulletin ®
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
