Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Computer Displays
Thread Tools Display Modes
Old 04-08-2012, 11:51 PM   #1
budm
budm's Avatar
City & State: S.F. Bay area
My Country: USA
Line Voltage: 120V 60Hz
I'm a: Knowledge Seeker
Default Inverter tester using old CFL
Do not throw away those broken CFL (14Watts or smaller), you can use them for testing your LCD monitor inverter circuits without buying spare lamps for testing.
You can solder the wires directly to the connectors on the inverter board or you can get the correct connectors but then you have to have more than one type.
I tested it out on my lamp tester board as you can see in the pictures.
I open up the lamp assembly using small hack saw just enough for me to crack it open, just be real careful.
Enjoy!
budm is offline   Reply With Quote
Old 04-09-2012, 12:05 AM   #2
retiredcaps
City & State: Canada
Default Re: Inverter tester using old CFL
Cool, I will provide this link in rev 0.4 of the 2 seconds to black guide sometime in the future.
__________________
--- begin sig file ---
--- end sig file ---
retiredcaps is offline   Reply With Quote
Old 04-09-2012, 12:08 AM   #3
budm
budm's Avatar
My Country: USA
How do you remember where the REV0.4 is? Is there a place in this forum that how to are kept?
Old 04-09-2012, 12:42 AM   #4
retiredcaps
Quote:
There is no formal tracking or process controls on this site as far as I know. I just keep my own thread and keep adding to the end of it and keep my own version control.
A bit unsophisticated, but is works okay.
Old 04-09-2012, 02:04 AM   #5
Jasgriff
City & State: England
My Country: UK
Looks good definitely a good idea for someone wanting to do a one off monitor repair. If you could even take out the lamps inverter board then solder the lamp directly to the bottom of the bulb fitting and glue the base back on. That way you could mount a bulb holder to you inverter tester board.
Retiredcaps any chance you could link to your 2 seconds to black in you signature then it will be easier to point people in the right direction
__________________
Fixed so far : 1 Home cinema system, 16 LCD Monitors, 4 LCD TV's
How to resize your pictures guide click HERE
Retiredcaps Ideal post example click HERE
Jasgriff is offline   Reply With Quote
Old 04-09-2012, 08:08 PM   #6
momaka
momaka's Avatar
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
I'm a: Hobbyist Tech
Nice experiment. I too was thinknig about trying the same thing but that experiment always got delayed or left for other projects.
Definitely good to know, though. I guess this will go on my "to-build" list now. Last month, we had a CFL light die in the house and I took it appart. Bad solder joints on the driving transistors (13003's) killed one of them. The CLF bulb probably still works, though. So looks like I have all of the parts needed .
Old 04-10-2012, 11:59 AM   #7
ashraf osman
City & State: egypt
My Country: AL Mansora
Best regards
A nice experience.
ashraf osman is offline   Reply With Quote
Old 07-15-2012, 06:17 PM   #8
budm
budm's Avatar
My Country: USA
Update with T5 4Watts lamp
__________________
Old 07-15-2012, 07:57 PM   #9
momaka
momaka's Avatar
My Country: U.S.A.
It's the hot Chilli Powder that makes everything work
Cool stuff
Old 07-17-2012, 03:47 PM   #10
dcooke570
City & State: Ridgebury, PA
My Country: USA
OK. I have 13w and 23w CFLs but no 14w.
Does the wattage matter if all I'm using is the top half?
dcooke570 is offline   Reply With Quote
Old 07-17-2012, 04:01 PM   #11
budm
budm's Avatar
My Country: USA
That will be too big (the 23W), 14w or smaller as shown will work. I did not try with other 13/14W with big body (such as used for under counter lights) yet to see if it will light up. Your 13W CFL twisted bulb should work.
Old 08-21-2012, 11:50 AM   #12
rogfanther
City & State: Curitiba
My Country: Brazil
Line Voltage: 127VAC 60Hz
Would the inverse also work ? Like, using a bulb inverter circuit to test the lcd lamps ?
rogfanther is offline   Reply With Quote
Old 08-21-2012, 11:56 AM   #13
budm
budm's Avatar
My Country: USA
The inverter for the HOME CFL is made for driving CFL with starting filaments, it does not use the high voltage (1500~2000V) for starting the Ionnization like CCFL does, CCFL does not have filament.
Old 08-22-2012, 06:45 AM   #14
rogfanther
My Country: Brazil
Oh, ok. Thanks.
Old 12-19-2012, 11:51 PM   #15
jlk69
Fix stuff
jlk69's Avatar
City & State: Chula Vista, CA
My Country: USA
Would this bulb work?
__________________
I fix therefore I am.
jlk69 is offline   Reply With Quote
Old 12-20-2012, 12:04 AM   #16
budm
budm's Avatar
My Country: USA
Way too big even though it is the same wattage. I tried many shape and size and so far the curly one with 10~14W seems to work well.
Old 12-20-2012, 12:31 AM   #17
jlk69
Fix stuff
jlk69's Avatar
My Country: USA
Wow, thanks for the quick reply. Looks like I will have to sacrifice a new bulb in the name of science. From the pictures I surmise that you don't need hook up to screen to test. Do you have to have a signal coming from the computer? Looks like that was not connected as well. Also, do all of the leads have to be hooked up to bulbs (mine has 4 leads for 4 bulbs?)?
Old 12-20-2012, 12:57 AM   #18
budm
budm's Avatar
My Country: USA
I force the bl_on line on mt tester board, you will have to have your monitor connected to the running PC but you do not need to have the screen T-CON connected.
You have to have 4 working lamps, if one failed or not connected, the inverter will go onto shutdown mode.
Old 12-20-2012, 01:13 AM   #19
jlk69
Fix stuff
jlk69's Avatar
My Country: USA
I was afraid of that. So I might need to make as many as 4 test bulbs? Or I could try hooking 3 up to LCD with 1 test bulb and hope only 1 CCFL is bad in my monitor and keep trying until lamps stay lit.
Old 02-20-2013, 10:59 PM   #20
Measuray
City & State: Pine Bluff, AR
My Country: USA
Enjoy!
Would a device like this workout more better?
http://www.lcd-pdparts.com/ViewDetai...ProductID=1813
CCFL & LCD TV Monitor Backlight Tester
VIP Price:$16.30
Last edited by Measuray; 02-20-2013 at 11:07 PM.. Reason: Forgot to add Youtube Video: CCFL Tester Laptop Screen Repair LCD TV Monitor ... - YouTube
Measuray is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2019
Powered by vBulletin ®
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
