Looking for Flash dump from Zyxel devices
  • highland
    • Aug 2020
    • 7
    I'm looking for flash dumps for my following bricked Zyxel devices;
    XMG3927-B50* (also accepted alternatives VMG3927-B50* and VMG8825-B50*)
    and also,
    VMG3925-B10*
    Thanks in advance for all your support.
    • 31131
    Re: Looking for Flash dump from Zyxel devices
    "The Zyxel XMG3927-B Series supports TR-69 that simplifies remote configuration, upgrade and management and therefore improves cost effectiveness and customer satisfaction. Additional support to the latest TR-181 issue-2 data model also enhances service providers’ visibility on subscriber LAN networks"
    backdoor infested junk - what isp supplied that unit??
    • highland
      • Aug 2020
      • 7
      From 'Elisa', FIN.
      It boots but it can't find config file and reboots. That zcfg_config file is missing. Can't update or upgrade via serial connection either. Perhaps, only option is to get a full flash dump and rewrite the nand.
        • 31131
        it probably has a serial port on the board, so you could get in with that.
        but you really need to convert it to openWRT or atleast cross-flash it to whatever the model was that was sold direct to the public without isp specific locks in it.
        • highland
          • Aug 2020
          • 7
          I've serial access to the device. The CFE is locked with new algorithm, which is different to known old algorithm. Thus, I can't enable 'BootExtension Debug Flag' to flash vanilla/generic firmware either. I know, some UK ISPs devices are not CFE locked and can be flashed to get rid of ISP traps.
            • 31131
            is the flash bga or something socketable?
            or is there an identifiable jtag port?
            • highland
              • Aug 2020
              • 7
              It is ESMT F59L2G81A, TSOP48. I've RT809H to flash the nand.
              Not identifiable JTAG port.
                • 31131
                o.k. try to find out what other model numbers are the same pcb.
                is it marked on the pcb?
                • highland
                  • Aug 2020
                  • 7
                  Not much idea about which other models share the same pcb, but I was confirmed that vmg3927-B50* and vmg8825-B50* also share the same bootloader as of xmg3927-B50*.
                    • 21403
                    might help - https://forum.kitz.co.uk/index.php/topic,23648.60.html
                    • highland
                      • Aug 2020
                      • 7
                      Originally posted by SMDFlea
                      Thank you for the link. The device's CFE Bootloader is locked thus I can't enable 'BootExtension Debug Flag' to be able to flash via serial/UART connection either. I need to reflash the NAND with an external programmer to unbrick it. I was hoping to get a complete NAND FLASH DUMP from any device similar or same as KCOM.
                      • spmetroil
                        Request: SPI Flash BIOS Dump (Winbond 25Q128) for Dahua NVR4216-4KS2
                        by spmetroil
                        I am trying to repair a Dahua NVR4216-4KS2 that is not booting.
                        The main BIOS/firmware is stored in an SPI flash EEPROM (Winbond 25Q128, labeled as U130 on the PCB).
                        I have a CH341A programmer and I already attempted the following steps:
                        1. Identified the correct chip (W25Q128, 3.3V SPI flash).
                        2. Tried to read the contents with CH341A Programmer software. The dump seems corrupted and I often get the error: “Chip with the contents are in disagreement.”
                        3. Compared several chip type selections (24Cxx and 25Qxx families) to confirm it is indeed a 25 series SPI
                        08-19-2025, 09:23 AM
                      • kooroshi60
                        Traktor Kontrol S4 MK1 Flash dump
                        by kooroshi60
                        Hi guys
                        I need the Flash Dump (.bin) file of the Traktor Kontrol S4 MK1. SPI chip number is 25DF041A from Atmel (4Mbit)
                        So please let me know if you have the .BIN Dump of this model and its price and the payment method.
                        I appreciate your help.
                        10-01-2024, 10:17 AM
                      • bamdad61
                        Canon DR-1210C flash dump request
                        by bamdad61
                        Dear folks, recently got a canon dr-1210c and it worked perfectly just for one day. Right now it shows all possible errors on the screen and do nothing. I tear down the device and found a 32 pin plcc flash chip. I thought reprogramming firmware might be helpful. The firmware update file from canon support include a dll file which doesn't help. So if anyone has the dump it would such a great favor to share.
                        04-15-2025, 02:43 PM
                      • corrize
                        Nikon D800 camera - flash don’t work and capacitor don’t charge
                        by corrize
                        Hello, I'm stuck in troubleshooting…
                        The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
                        In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
                        When I press the flash button, it's detected by the system, flash icon appear on LDC display....
                        10-01-2022, 10:02 AM
                      • numerlor
                        lenovo P720 SIO flash dump
                        by numerlor
                        Hi, the SIO firmware flash in my lenovo P720 seems to be corrupted, after a reboot POST fails with CPU1 fan failure and all fans set to max, proceeding with booting shows SIO FW no response.
                        I've tried using the lenovo sio update utility but that fails with "EC Autho Value not Match" when the system reboots for the update. The efi update tools has a S04FW.cap file but it's 256kb which seems too small?
                        S/N S4PD6489...
                        06-23-2025, 01:22 AM
