I picked up a Vizio VX32L last week that has turned into a pain in my backside. I narrowed the problem down to a bad voltage regulator on the main board, but screwed up trying to replace it. I found a website that cross referenced the board number with two other boards. I found one of the cross referenced boards on eBay for a price that I could live with. The board came in today and I put it in the TV. I get power for 3 seconds and then nothing. I went through the voltage regulators and they all seem to be good, so I turned to the fuses. In the picture below, the fuse on the right (the vertical one) shows to be open. Figuring I am done with this set, I jumpered the fuse and hit the power button. The thing came to life and has a good picture and good sound. I immediately shut it down at that point and removed the jumper wire.
With that said, will running jumpers from the ends of the bad fuse to the ends of the good fuse on the bad panel be test enough to tell me if I can just replace the fuse?
