Samsung UN55H6350 no image, has sound -Bad T-con or Panel?
  • lfhlaw
    • Mar 2014
    • 115
    I got this Samsung UN55H6350 was told it had sound but no image.
    Took the back off. I do have power, and it powers up the main board with sound.
    If I disconnect ribbon from Main board to T-con, I get backlight to come on - No image obviously and still have sound.
    With Ribbon to T-con connected and ribbons to panel connected - backlights are off.
    With Ribbon to T-con connected and one of the ribbons to panel connected, all the lights come on but no image.
    Doesn't matter which ribbon to the panel is connected to the T-con as long as it's one or the other and then all the lights come on, but still no image.
    I included pics with the ribbons disconnected and backlights as an example.
    I did purchase a Main board and T-con from Ebay without much improvement.
    Bad T-Con or Panel? Didn't know if you needed pics, but I included them just in case.
  • nomoresonys
    • 12331
    • U.S.
    Re: Samsung UN55H6350 no image, has sound -Bad T-con or Panel?
    Test all pins on connector from mainboard to powerbard on powerboard side, all boards connected. Test in standby/plugged in but off, then apply power report both conditions, example: pin 1 bl-on=0 volts standby and 3.3 powered on, report results for every pin. How to video in my signature below.
    • lfhlaw
      • Mar 2014
      • 115
      Plugged in, standby
      pin 2-1 10.8 v
      pin 4-3 10.8 v
      pin 6-5 10.8 v
      pin 8-7 10.8 v
      pin 10-9 0v
      Plugged in, Power on
      pin 2-1 12.8 v
      pin 4-3 12.8 v
      pin 6-5 12.8 v
      pin 8-7 12.8 v
      pin 10-9 0v
      • nomoresonys
        • 12331
        • U.S.
        Theres 10 pins, you checked 13579 now check 2468.
        • lfhlaw
          • Mar 2014
          • 115
          How do I do that? if you look at picture of the back of the connector...there's only 5 wires. not 10. I'd have to detach the cable to the main to see all 10 pins and test them unless i'm not understanding what you're saying or there's another approach.
          • lfhlaw
            • Mar 2014
            • 115
            so anyways I did remove the cable to the main and powered on the board and tested the even pins.
            pin 2 was 2.3 v
            4 was 3.3 v
            6 was 3.9 v
            8 and 10 were 0 volts as expected as both are ground (i'm assuming)
            • budwich
              • Jul 2015
              • 3097
              when you disconnected one of the tcon to panel cables, what happen to the display... you indicate no image but is the display white on the disconnected side?
              • lfhlaw
                • Mar 2014
                • 115
                Yes white on both sides still or the LEDs are lit to both sides and no image.
                • nomoresonys
                  • 12331
                  • U.S.
                  Check if you have voltage on each side of tcon fuse, black probe on a ground. Fuse is probably white labeled F1.
                  • lfhlaw
                    • Mar 2014
                    • 115
                    I don't see the Fuse.
                    Might be a stupid question, but do i need to remove the black Heat sink? (I think it's the black heat sink?) or could you circle on the T-con Picture where it is if I don't have to remove the black heat sink?
                    • nomoresonys
                      • 12331
                      • U.S.
                      Right there by your connector, white fuse labeled F1, nothing needs removed to see it.
                      • lfhlaw
                        • Mar 2014
                        • 115
                        Ok Tested the fuse with the TV Power on and got 12.8 Volts
                        • lfhlaw
                          • Mar 2014
                          • 115
                          Any other testing? or more a panel issue now?
                          • nomoresonys
                            • 12331
                            • U.S.
                            Guess you could have bought a bad board, did you try both mainboards with both tcons, meaning each mainboard tried with both tcons? and when the backlights are off with everything connected try shining a flashlight at the screen maybe hit menu on remote and see if you see any text, logo or anything.
                            • budwich
                              • Jul 2015
                              • 3097
                              you likely need to check for voltages at the various TP on the tcon and then trace those towards the panel board especially focused on the side that doesn't work.
                              • lfhlaw
                                • Mar 2014
                                • 115
                                Yes I did try both boards and T-cons mixing and matching with no luck.
                                I did the flashlight test and no image or Menus whatsoever.
                                • lfhlaw
                                  • Mar 2014
                                  • 115
                                  Both sides don't work.
                                  The White i think i was referring to earlier is more the LEDs rather than a white "image". The screen itself is blank or dark.
                                  What does "TP" stand for in the "various TP on the tcon"?
                                  • Andrew F. Ali
                                    • Jan 2014
                                    • 2450
                                    • Trinidad & Tobago
                                    A bad Panel. No fix.
                                    • budwich
                                      • Jul 2015
                                      • 3097
                                      post a picture. Either way, check the various TP voltages on the tcon. outside of that, you would need a scope to trace signals from the main board, to the tcon, to the panel.
                                      • nomoresonys
                                        • 12331
                                        • U.S.
                                        TP stands for test points.
                                        • wolf1976
                                          samsung ue40d6100 has no backlight no sound and image
                                          by wolf1976
                                          hi to all
                                          on the above model of samsung i have the faults i have told already on the title
                                          iI have standby i can from remote control open and close the tv and it seems reacts the tv when i press someone button from remote control but and with the help of a torch i cannot see anything image on the tv and no sound
                                          any idea from someone what can i measure so i can find the problem ?
                                          the power supply is the bn44-00482a i cannot find the service manual so i can test if the leds are ok and maby these are the cause of my problem
                                          11-17-2024, 01:02 PM
                                        • rimwall
                                          Sony KD-65x7500D - double image - Tcon or Panel?
                                          by rimwall
                                          This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
                                          I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
                                          11-18-2025, 02:09 AM
                                          09-07-2024, 05:50 AM
                                        • Ierwin
                                          by Ierwin
                                          05-13-2025, 03:31 PM
                                        • ChaosLegionnaire
                                          by ChaosLegionnaire
                                          09-13-2022, 09:02 AM
